Results 1 to 8 of 8
- Oct 2011
- 10
October 20th, 2011 07:51 PM #1[SIZE=3]Mga sir ask ko lang po kung alam niyo kung anong sensor/part ng engine ng ford escape itong picture na ito. Nasunog kasi e hindi ko alam kung anong cause bakit nasunog. Thanks.
[/SIZE]
THE AUTO SPECIALIST
- Mar 2006
- 607
October 20th, 2011 08:25 PM #2that must be your exhaust back pressure sensor ( EBP sensor) .get it diagnosed by a qualified tech ,
chances are you may have a clogged up CAT CONVERTER . using an exhaust pressure gauge ,the tech
should determine the condition of the CAT . *2500rpm it should read less than 2 psi .
- Oct 2011
- 10
October 20th, 2011 09:59 PM #3Thank you sir for the answer. Just 1 question, is it safe to travel? baka itirik ako or kung ano mangyari kasi
THE AUTO SPECIALIST
- Mar 2006
- 607
October 20th, 2011 11:50 PM #4kung malapitan lang naman or sa malapit na casa ok lang siguro ,pero observe pa rin since toasted yung part mo baka mag cause ng fire sa engine bay yung trouble .the best tow na lang sa trusted technician mo .
- Oct 2011
- 10
October 23rd, 2011 01:42 AM #5for now wala pa wkasi akong makitang mechanic e, kung sa casa kasi baka mataga naman ako sa price may i know if you know a good mechanic for ford cars?
October 23rd, 2011 10:41 AM #6
one of the possible cause nyan pagkasunog ng dpfe sensor ay baka barado ng carbon yang egr tube (may butas na parang
orifice yang loob ng tube sa pagitan ng 2 hose). linis lang katapat nyan, kung duda ka sa catalytic converter hanap ka na
lang ng shop na may scanner na kayang bumasa ng oxygen sensors
- Oct 2011
- 10
November 7th, 2011 07:49 PM #7ok sir t2erns thanks hahanap pa rin ako ng mekaniko for now halos kasi yung iba hindi daw kabisado yung ford na sasakyan
- Jul 2003
- 573
November 7th, 2011 08:38 PM #8kaya ba makita sa OBD2 scanner ang trouble kung sakali?
saan area malapit location mo?
high idle RPM at engine start
