Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    May 2013
    Nakabili po ako ng Corolla GLI 93 model 16 valve EFI engine. Minsan may usok na kulay bluish na lumalabas, minsan wala naman. May nakapagsabi normal lang daw, meron naman CV valve daw, meron ding nagsabi Valve seal daw. Ano kaya to?
    Feb 2013
    Baka nagsusunog ng coolant yan or ng kung anuman na fluid na di nya dapat sunugin.
    May 2013
    Kaya nga minomonitor ko rin everyday kung nagsusunog ng oil. Pero di naman kc nababawasan engine oil nya.
    Feb 2003
    IMHO pag coolant nag whitish ang smoke..steaming out. But in my experience a bluish smoke indicates Oil burning. Just look at the 2strokes motorcyles. Their smoke is bluish kse nag add sila ng 2T sa Gas nila. If not a worn out piston ring then most probable nga sa valve seats ng exhaust valves.
    May 2013
    Sensya na po kase baguhan lang ako sa mga sasakyan. Eh di naman kc nababawasan yung engine oil everytime na i-check ko.
    Feb 2003
    You have to check if the oil is getting thinner or nag aamoy gasolina na.....baka kaya nd nababawasan sa level na dilute na ng gasoline..possible din un. from worn out piston rings. A bluish smoke will not really eat up a lot of oil ...well it would be depending of number of hours you use it.
    I pa compression testing mo para mkasure if maganda pa ang results then it's from the valve seals. Mas maaga mo mapaayos mas makakatipid ka in the long run. Wala pang abala sa daan.
    May 2013
    Salamat po, ipapa-check ko na nga po.
    Quote Originally Posted by ceekeigh View Post
    Best guess, its an oil leak into the cylinder. Probably the gasket or the one of the piston rings have failed.
    To confirm the leak, have a cylinder compression test done. Its quick and would pinpoint which cylinder has the problem.
    Jan 2011
    valve seal?
    May 2013
    Quote Originally Posted by shelu View Post
    valve seal?
    Yun po yung isang sinabi sa aken eh. Di ko rin po kc alam yun.
    Jan 2004
    Kelan may bluish smoke? Sa una lang pag malamig? O kahit mainit na ang makina? Paano ka nagche-check ng oil level?
    you're burning oil
    check for:
    - loose compression
    - valve seals leak
    - pcv valve stuck open
    Jan 2011
    no problem if PCV lang. pag valve seal, medyo magastos ng kunti. top overhaul na rin kasi yan. grind ang valves then setting. act on it asap dahil baka lalaki pa ang problema.
    Oct 2009
    baka matigas na ung valve seal,,,
    kaya pumapasok na ung langis sa loob ng head , sa mga valve
    result hindi naghahalo na ung langis at gasolina...kaya umuusok...
    May 2012
    Totoo po ba na yung konting symptoms ng blow by kaya pang ma remedyohan ng oil additive and medyo makapal na oil like 15w40?
    The additive that he mentioned is ceratec though di naman sila nagbebenta nun.
    Any comments mga sir?
    May 2013
    Quote Originally Posted by the_wildthing View Post
    Sa una lang po pag malamig yung makina. Tapos mawawala din. Every morning dun ako nagchecheck ng oil level.
    Jul 2011
    worn out valve seal i guess.. sa umaga, malamig makina, meh uwang ng maliit sa mga seals, kaya pag cold start may bluish smoke, pag nag-operating temp na, nageexpand ang seal dahil sa init kaya wala na lumulusot na langis.
    May 2013
    Quote Originally Posted by hachooro View Post
    Any comments po dito? Para oil additive na lang sana.
    Jan 2013
    typical symptom din to nang oil sludge
    May 2013
    Oks na po. Valve seal nga po yung tama then yung valves pinapalitan ko na rin kc masyado na manipis.
Bluish Smoke (ano kaya problema ng kotse ko?)
