Results 1 to 13 of 13
    Apr 2008
    hi guys,
    tanong ko lang saan pa possible causes ng oil leak. my car's civic 96 vti. everytime i leave my garage may droplets of oil. although small lang naman. the actual drops are from the splash shield although i'm not sure where exactly it's coming from. sa may area siya ng compressor.
    i had it checked and replaced the following:
    -oil pan gasket
    -crakshaft seal
    -camshaft sea
    -cylinder head gasket
    -distributor o-ring
    TIA
    since madami ka na napalitan, i think its best to really isolate it.
    di mo ba makita kung san nangagaling? if not, ipa lifter mo.
    Apr 2008
    actually pina-lifter ko na siya and hindi talaga makita saan galing. sa term nga natin is "nangangabay" ang oil. i tried to look for the source myself and i noticed that the lower half of the engine block at the rear is oily.
    i've read somewhere that the pcv valve maybe the culprit. possible ba na tumagas ang oil from the pcv?
    kung meron smoke tester yung shop makikita kung saan yung leak
    engine wash then observe kung saan nagmumula ang leak. mahirap makita kapag marumi IMO.
    Apr 2008
    thanks guys...will do as advised. hopefully ma-solve na.
    Apr 2008
    update ko lang..naayos na car ko. oil pump o-ring ang salarin. hehe! thanks speedyfix!
    Apr 2008
    update ko lang. naayos na car ko. oil pump o-ring ang salarin. hehe....thanks speedyfix!
    Nov 2003
    glad we could be of help
    Jul 2018
    Same problem po sa akin ngayn at oil pump o-ring dn ang sabi ng mekaniko sa akin.
    Jul 2018
    Sir tonyboy. Pinalitan lng ba yng o-ring ng oilpump mo then ok na?
    Here's the suspect: the oil sending unit .
    I replaced it over the weekend.
    I hope this solves my oil dripping woes. Pati Iyong 2 aso ko na mahilig matulog sa ilalim Ng sasakyan oil matted parati Ang fur.
    Imgur: The magic of the Internet
    https://i.imgur.com/1Kryt11.jpeg
    ^ Sana nga yan na. Nice job.
Oil leak
