Results 1 to 10 of 10
    mga sir help nmn po....i have my corolla 1989 model 1.6 Gl.....2nd hand.....anu po ba kaya problem nito kasi my napapancin akong oil leak sa air filter...sabi kasi sakin baka daw bibigay na un makina......sa tingin nyo po ba anu diperensya?
    May 2007
    This is what is called 'blow by.' Changing out the PCV will help this out. Change the filter as well. I assume this is a higher mileage vehicle. You might want to pull the intake and clean all of the carbon out of the valley. Better gas/performance will be a result.
    sir thank you for your reply.....BTW what is PCV? im just new here and i'm not particularly good enough with this problem...... your reply would be a great help....thank you sir...
    May 2007
    Quote Originally Posted by lowrider17 View Post
    Like this one depend upon the year.
    The PCV valve connects the crankcase to the intake manifold. Ask your mechanic he know's exactly where it is.
    PCV means positive crankcase ventilation.
    It depressurizes the crankcase from normal and abnormal blowby.
    Without this, pressure will build up and will find an outlet to release and the weakest exit is the front and main oil seal.
    ok...mga sir thank you sa reply nyo.....it would be a great help tlaga....sana un ung problem kc un recomend nun mekaniko e ipa overhaul ko na daw un makina.....thank you ulit...God speed..
oil leak
