Page 1 of 2 12 LastLast
Results 1 to 20 of 73
    Sep 2010
    Hi everyone,
    Does drain plug "washer" is really required to replace after a change oil? The reason is, I inquired a non-casa shop and ask for quotation of a change oil. To my surprise, it cost 90 pesos for the washer alone. Akala ko makakatipid ako ng onti kapag hindi casa, since they also charge me for drain plug washer everytime na magpapa change oil ako hehe.
    90 pesos is a small amount, but hey katumbas na rin un ng isang budget lunch meal.
    TIA!
    Quote Originally Posted by akosijhay View Post
    Hi everyone,
    TIA!
    for an item that normally costs pennies, 90 bucks is highway rubbery.
    some replacement oil filters even include it in their package, free.
    chances of leak are less, if one used a new washer and not re-use the old washer.
    Hi everyone,
    TIA!
    I do my oil changes. the washer gets damaged over time even with the right torque anyways. replace it every after oil change(6 month interval)
    Those are crush washers designed to get compressed to maintain a good seal with the pan. Used ones might not seal well anymore. That's why it's prudent to just replace them every oil change.
    Jul 2019
    Totally agree. it's better to spend few bucks more to avoid leakage overtime. than to drain the whole pan just to replace the faulty washer. some washers are made of copper or alu and some are with rubber lip on the inner dia. Some service shops are using a suction pump with the hose inserted on the dipstick tube down to the bottom of the pan to drain the oil.. that leaves the drain plug untouched in its place permanently.
    Quote Originally Posted by nelyoung View Post
    Makes em good candidates for seized plugs.
    Jan 2008
    Installed the fumoto valve.. nice fit to my 4d56 engine!
    The package comes with a fumoto clip and the seller included the plastic nipple with hose extender..
    The valve does not protrude.. just like the old drain plug.. its just longer by 10mm and in no way can be hit by rocks underneath..
    Jun 2005
    Palitan tuwing oil change. Bilhin mo sa casa kung gusto mo. Wala pa 50 pesos isa nyan.
    Or bumili ka sa lazada. Murang mura lang. Nasa 200 isang pack of 10
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    tingnan ko iyong sa lazada.
    badtrip wala sila for mitsubishi.
    universal ba ang mga ito bro?
    hyundai uses aluminum washers. this is better for high temp applications imo.
    we use copper washers for high pressure gas systems. for low pressure nylon/fiber washers.
    Jan 2008
    Saw fumoto drain plug valve now at lazada.. ordered 1 to try! Good for DIY oil change
    [emoji106]Be sure to cross reference part number w/ make/model/year & grab the LC10 lock clip.
    Sa casa ka ba lang bumili mas mura pa. Tinataga ka nun shop.
    ditto
    sa toyota casa mura wala pa 50 isa
    sa tabing auto supply 20-30 isa
    Jan 2009
    I buy bulk from Lazada and replace it every oil change. A 10-pack just costs around P150.
    Mar 2018
    For your peace of mind, change it. Mura lang naman.
    May 2019
    It wouldn’t hurt to change it, but I’ve been reusing them for many years without any issues.
    Fumoto...1 step less w/o the mess. Drain, fill & drain when over filled...w/ ease. No more crush washer replacements.[emoji4]
    Cool stuff bro. 👍
    Cool stuff bro. [emoji106]
    Grab the original, not some equivalent. Simplifies life.[emoji4]
Does drain plug washer is really required to replace every oil change?
