Results 1 to 4 of 4
- Oct 2008
- 19
October 29th, 2008 10:33 PM #1my mixture ng oil ang radiator ko and my mechacic says sira na ang oil cooler ko. try ko nagkanvass dito sa province ( i'm from LA UNION for the matter) and medyo mahal ang presyo nila. 8k daw ang genuine parts na ito.
please help, san po sa banawe or any auto supply pwede makamura.
needs address and phone number if possible para ako na lng tumawag sa kanila. //THANKS.
December 15th, 2008 09:05 PM #2
Oil cooler? Correct me if I'm wrong but AFAIK, walang connection ang oil cooler sa radiator because it has its own radiator/cooler. Same principle as cooling the water in your radiator. It could be that you have a leaking cylinderhead gasket in your engine wherein the oil gallery leaks into your water gallery.
- Oct 2008
- 19
December 26th, 2008 10:01 PM #3yes bossing, nahanap na rin namin problema. not from oil cooler pala, but from oil cooler stand, ung kinabitan ng oil cooler attached sa engine block. may part kasi doon where dumadaan ung water from radiator, at the same time my part din doon where oil goes to the oil filter, basag pala siya kaya ung pressure nung oil pupunta sa my water palabas sa my radiator. thank god nawala na rin ung oil sa radiator.
have my oil change na rin, and now i'm looking for the thread where i can find some answer kung ano disadvantage ng over sa maximum and nalagay sa engine ko. almost a 3rd of an inch kasi sumubra.
thanks for the reply any way.
January 11th, 2009 03:10 PM #4
i also replaced my oil cooler last august 2008, yung oil cooler kasi ng 4ja1 nabubutas din daw talaga kapag matagal na medyo manipis yata yung wall separating the water and the oil. i got my replacement parts at blumentrit almost 3k kuha ko. orig is 7k-8k nga yata talaga.
Wala naman sigurong effect kung medyo mahaba ng konti yung naikabit sa auto mo basta walang leak and ok ang flow ng water and oil sa oil cooler mo.
Xiaomi E-Car
