Yes the HT leads are the 4 thick black wires that run from the front top part of your engine to where your spark plugs are supposed to be. Over time the rubber insulators of the HT leads degrade and crack.
My apologies. By "bonnet" I actually mean the car's hood. It's a British term.
You should not have silicone sealant anywhere along the course of the HT lead so I suggest you have them looked at.
Again, check the systems one by one and make sure your mechanic is good at troubleshooting and not some "Ser, palitan na lang natin 'to at 'to at 'to na rin..." type of lazy mechanic...
first, check the valve synchronization by using a vacuum gauge connected into a non ported vacuum source like the PCV hose. regardless how good the ignition system is or how good fuel delivery and atomization is, if the valves are late it will limit power, speed and suffer in fuel efficiency. the engine vacuum at idle for normally aspirated engines without racing cams should be between 17-21 inHg. most vacuum gauges would tell you the valves are late if the engine vacuum is lower than 16 inHg. or, you can remove the upper timing belt cover and check the timing marks on the cam pulley and the timing belt backing plate while the crank pulley is at TDC position. if after verification of valve timing is satisfactory, check the ignition system, fuel pressure, fuel volume over a period of time and check the exhaust system for possible restriction
