Quote Originally Posted by ambasad0r View Post
Guys I have some problem with my nissan exalta.
Last day kasi pina ayos ko yung car dahil nag ooverheat due to leaking head gaslet. So pinapalitan ko yun then after that okay na wala na yung leak at di na nag ooverheat. Upon testing for a drive napansin ko pag naka naka engage yung gear ( 1,2,D or R) parang nanginginig sya. When going to full stop parang mamamatay yung makina kasi ang lakas ng vibration. Kaya ginagawa ko nilalagay ko sa N kapag nag ffull stop.
Another one is himuna yung hatak ng sasakyan lalo na pag paakyat kailangan i floor yung gas para maka akyat.
Need you help mga sir. Before ko kasi pina service yung car di naman ganito.
Check all the following:
-Ignition timing
-compression test the cylinders (potential back job if it fails this)
-Spark plug
-Spark plug wires
-throttle body cleaning
-air filter
-fuel filter
By the way, how long was your car in the shop when you had the engine overhauled? Does the gasoline smell bad (stale fuel).
