Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Apr 2005
    Quote Originally Posted by goldencoil
    A/F Setting? Is it Air/Fuel Setting? Paano ba kino correct yun?
    try to search na lang. na-discuss na yan before. kayang-kaya mo i-diy.
    Sep 2009
    up ko lang po ito..
    Pansin ko din kasi na puno fuel filter ko..wala pang 2 months yun...
    Hindi po siya normal?
    corolla 1.3 carb po pala car..
    TIA..
    Jul 2003
    what will go wrong if the fuel filter is full? The amount of fuel insside the fuel filter can be full or just half of its capacity. So long as you have correctly installed the fuel filter with the nipple flow arrow pointing toward the direction of the carburetor, then that will be fine. the location of the fuel pump will play a role on the amount of fuel in the filter. If you have an electric fuel pump located before the filter, the filter will be full. If the fuel pump is suction type after the filter, the filter may or may not be full of fuel. If the filter is full and nothing comes out of it, then that filter is clogged.
Normal bang napupuno ang Fuel Filter?
