Results 1 to 10 of 13
August 11th, 2005 09:04 AM #1
I recently changed my Fuel Filter. Napansin ko na halos puno na yung nasa loob. May nagsabi sa akin nde nde normal yun. Is that true? If yes, what could be the problem?
August 11th, 2005 09:10 AM #2
bka clogged yung isang end mo ng fuel filter. but talagang may matatapon na fuel pagnagpalit ka ng fuel filter.
August 11th, 2005 09:16 AM #3
So nde pala normal yun. Could that be one reason kaya minsan mataas ang idling ko. Like one day, nasa 1,500 RPM tapos minsan nasa 900-1000RPM lang. What do you think?
August 11th, 2005 09:22 AM #4
walang effect ata sa idle ang fuel filter mo.. kung luma na yung filter mo masmagandang palitan mo na.. kasi ang fuel lines all the way sa fuel injector kung meron yung oto mo e puno ng fuel yan. so pagnagpalit ka ng fuel filter may laman talagang fuel yan kahit anong linis pa nyan o dumi. kung hesistant yung engine mo umarangkada when you step on the gas e isa sa reason ang clogged fuel filter which is madumi na at the same time baka madumi na rin yung injectors mo. kaya mas ok kung kada oil change mo sabayan mo ng lagay ng fuel cleaner yung gas tank mo para malinis yung fuel lines mo
August 11th, 2005 09:36 AM #5
Bago lang kasi Fuel Filter ko. One month pa lang. BTw, naka CARBURETOR ako. Does it make any difference
August 11th, 2005 10:52 AM #6
AFIK, dehins normal yan. Dapat ang highest level 'ata nya is nasa 1/2 the capacity or even less.
August 11th, 2005 03:13 PM #7
baka mataas A/F settings mo. ganyan din kotse ko before namin in-adjust. ngayon half na lang laman fuel filter. mataas fuel sa mix.
August 12th, 2005 11:35 AM #8
Originally Posted by maverick34
August 12th, 2005 12:40 PM #9
diba dapat may small bubble ang filter otherwise magcloclog? not sure, sa diesel ko kasi dati mga 2/3 full lang sya lagi
- Aug 2005
- 10
August 12th, 2005 01:03 PM #10Kapag madumi na ang fuel filter ng Carb type engine, Could this also be a reason for hard starting specially in the morning?
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
