Originally Posted by
laserbim
Hi,
Toyota Innova 2012 G VVTi Gas, Brand new, 800km odometer. This topic should be applicable to any car too.
Need your advise please.
What are the important points to consider before leaving the car unused for a very long time, say 12 months. And nobody will be able to start the engine periodically. It will be totatlly unused.
Here are a couple of points I thought but they may be wrong too. Please add your inputs or comments.
Prior to leaving the car unused:
(On appearance)
- Make sure you cover the entire car using a Car Cover to protect against heavy dust, sun, and rain
- Inside the vehicle, use a moisture and odor absorber by putting lots of silica gel and charcoal
? What else?
(On Tire)
? It will definitely deflate over the 12 month period and there is a risk that the tire's shape will get oblong. What to do?
(On Engine and Lubricants)
? What to do about the engine oil..should we drain it or leave it as is?
? What to do about other fluids like brake, steering, gear, windshield washer, etc? Drain them or leave them as is?
(On Battery)
? Disconnect the Battery or not? If we disconnect, then keyless entry will not work and we will have to manually open it using a key. I guess this will be a personal choice. But any implications of disconnecting it or not?
Things to do when you want to use the car again after the long period:
(On appearance)
- Maybe get an interior detailing service or clean it thorughly yourself
? Do we have to replace the engine oil and other lubricants first?
(On Tire)
? Can we still use the same tire safely?
And a general question: Will there be negative effects to the engine even after following the preparations above after leaving the car unused for many months?
