Results 1 to 10 of 22
- Feb 2007
- 80
May 22nd, 2012 07:02 PM #1Hi,
Toyota Innova 2012 G VVTi Gas, Brand new, 800km odometer. This topic should be applicable to any car too.
Need your advise please.
What are the important points to consider before leaving the car unused for a very long time, say 12 months. And nobody will be able to start the engine periodically. It will be totatlly unused.
Here are a couple of points I thought but they may be wrong too. Please add your inputs or comments.
Prior to leaving the car unused:
(On appearance)
- Make sure you cover the entire car using a Car Cover to protect against heavy dust, sun, and rain
- Inside the vehicle, use a moisture and odor absorber by putting lots of silica gel and charcoal
? What else?
(On Tire)
? It will definitely deflate over the 12 month period and there is a risk that the tire's shape will get oblong. What to do?
(On Engine and Lubricants)
? What to do about the engine oil..should we drain it or leave it as is?
? What to do about other fluids like brake, steering, gear, windshield washer, etc? Drain them or leave them as is?
(On Battery)
? Disconnect the Battery or not? If we disconnect, then keyless entry will not work and we will have to manually open it using a key. I guess this will be a personal choice. But any implications of disconnecting it or not?
Things to do when you want to use the car again after the long period:
(On appearance)
- Maybe get an interior detailing service or clean it thorughly yourself
? Do we have to replace the engine oil and other lubricants first?
(On Tire)
? Can we still use the same tire safely?
And a general question: Will there be negative effects to the engine even after following the preparations above after leaving the car unused for many months?
May 22nd, 2012 07:31 PM #2
things i gave thought over din before i left for a month. buti was able to park my car sa di naarawan. tapos, just inflated my tires to around 40 para nga ma-minimize pagka-oblong. didn't disconnect the battery na rin coz of the keyless entry nga. parang me nabasa akong effect daw pag nawalan ng supply ang alarm. when i arrived though, me karga pa naman battery pero can't crank the engine na. so i just used a jumper cable sa kabilang kotse. but mine is one month nga lang, so will be waiting for inputs too from the masters here for the TS's case..
- Feb 2007
- 80
May 23rd, 2012 08:15 AM #3I had one experience in another car of mine. i left it unused for about two months. I did not take any measures at that time. When I came back, the interior of the car had presence of molds and had odor. It was rainy season back then. So that's why I posted above that maybe the learning is to ensure that I put a lot of silica gel and charcoal. Battery got drained too as I didnt disconnect it prior to leaving the car unused. But maybe because my alram system was kinda faulty...
Any other thoughts guys?
May 23rd, 2012 09:32 AM #4
I work abroad for 4-6months at a time and my car almost sits that long also. It only gets used twice a month by my wife, kahapon she told me na nag dedeflate daw yung isang tire and when she had it checked ok naman yung valve at walang leak so i'm guessing na nag oblong na yung gulong.
So my question is, pag nag oblong ba babalik pa sa original shape if ma gamit na ulit?
May 23rd, 2012 09:32 AM #5
this procedure is called "pickling the car". from ground up:
for extended period of time:
reduce the tire pressure and protect from UV rays
raise the vehicle and support with jackstands to unload the suspension
from under the hood,
a. change the engine oil and filter and let oil circulate until warm
b. change the brake fluid and cover the master cylinder air tight (toyota master cylinders are vented allowing moisture to seep into it)
c. check the protection level of the anti freeze/coolant, if okay, retain
d. check the transmission fluid
e. lubricate hood hinges, hood latch and cable, lubricate transmission linkages
f. protect the battery terminals and battery cable clamps with vaseline to avoid corrosion
g. if leaving the battery connected, install a battery trickle charger, if not, disconnect battery
h. use animal repellent under the hood and around the fuel tank area
the fuel system:
leave at least half tank of fuel and add fuel stabilizer
the exhaust system:
block the exhaust tail pipe with steel wool to prevent mud bees, small insects and rodents from housing inside
the car's body:
lubricate door hinges( with vaseline) and locks(with spray oil), lubricate fuel door hinge
protect the interior by blocking sunlight into the upholstery and dash
protect the exterior with breathable fabric car cover and further cover with non permeable sheet (polyethylene plastic)
and last but not the least, protect car from vandalism and theft in a secure, weather resistant enclosure.
- Oct 2009
- 2,271
May 23rd, 2012 05:59 PM #6and last but not the least, protect car from vandalism and theft in a secure, weather resistant enclosure.
yan ang pinaka importante he he he..:D
- Dec 2003
- 137
May 24th, 2012 05:04 PM #8Unused for 12 months? Sell it. Invest the money on something low risk. Buy a new car upon return. Least amount of headaches.
May 24th, 2012 05:08 PM #9
Isa pang kalaban ang mga daga.
Have you inquired with facilities like Alex Car Storage?
Have no idea on the price though.
Car Storage by Alex RestorationLast edited by vinj; May 24th, 2012 at 05:10 PM.
Daming issue ng SU7:grin:
Xiaomi E-Car
