Good day mga sir.
Just had a Dry compression check with my Ride Nissan Lec-PS 1994 on a reputable nissan shop in pasig medyo may onting grey /white smoke kasi during idle recently yung auto ko kaya pinacheck ko na for compression test.
So far the reading is 150,150,150,170 i was advice that their be doing the dukot style kasi daw black carbon filled na rin yung spark plugs pero hindi basa, sa kinalaunan baka daw masira head pag mapabayaan. Mga sir nagpagawa po ako ng JO sa kanila.
  • Top Overhaul 6500 (labor)
  • Crankshaft oilseal (480)
  • Cylinder head gasket 2100
  • Valve seal set (1440)
  • Free tune up
  • Castrol oil 875
  • Spark Plugs 600.
May question sir is base po ba sa reading ng dry compression test. Diprensiya na po ba talaga and 1,2 and 3 (150,150,150)?
Should i go for the top overhaul? After daw ma top overhaul ma eliminate na raw yung smoke and tatagal pa ang buhay ng makina. alagaan na lang daw sa tune up and tubig after.
Will this benefit me in the long run? or my iba pa po bang way para mawala smoke? i heard try to replace rocker gasket daw sakit ng Nissan daw kasi yun pag mausuok.
Pa feedback mga master
Salamats po sa lahat!
