Results 1 to 4 of 4
- Jun 2009
- 19
June 19th, 2009 02:52 AM #1Mga SIR,
ask ko lang po opinion nyo with regard to my car issues.
1. I could not start my engine.
2. My check engine light is on and won't turn off.
3. Nagbabawas ako ng tubig.
4. at nagiingay yung sa timing belt side ng engine ko.
Your inputs would be gladly appreciated.
I'm from las pinas pala. can you guys recommend some good mechanicsor Shops?
Thanks,
Bang
- Mar 2009
- 18
June 19th, 2009 03:13 AM #2
- Jun 2009
- 19
June 25th, 2009 03:02 AM #3Sir Thank you!
Nag self diagnose ako. tried to check yung MAP sensor, ok naman yung lumalabas na kuryente. Sinubukan ko bunutin yung main relay, at bumalik sa dati yung pagsindi at pagwala ng CEL (check engine light). pero naiistart ko naman na sya. Ang problema parang pumupugak ang takbo at pag naka idle umiilaw yung Check engine ko. Sinubukan kong i jumper yung service connector pero walang codes na lumalabas..
ano sa tingin nyo mga sir?
June 30th, 2009 06:36 PM #4
for your case mukhang mahirap na idiagnose kung hindi lumalabas na via service connector. Dalhin mo na lang honda casa for diagnostics via omputer mismo or try other shops like speedlab/speedyfix I think they offer those types of diagnostics... wala pang 1K yan.they will give you the print out kung ano mga nadedetect na faulty parts
