Results 1 to 10 of 10
- Aug 2013
- 3
August 11th, 2013 04:31 PM #1Hi guys i have a nissan cefiro 99 model. Ang problem is ok naman sya pag start tapos habang umaandar bigla nalang namamatay kahit nakaapak ka sa gas as in sunod sunod namamatay pero pag iniistart naman ok sya. na try ko na palitan yung fuel pump, and fuel filter and ang dami na din tumingin na mekaniko pero hindi nila makita yung problem. pa help naman po kung alam nyo yung solution thanks.
August 12th, 2013 10:37 AM #2
try to clean up the throttle body first.
change plugs
check the distributor
check hi tension wires.
- Aug 2013
- 3
August 12th, 2013 01:55 PM #4Hi sir na check ko na din pero it seems wala naman dun ang problem. may times na parang ayaw din humila sasakyan while stepping on the gas and mamatay sya pag inaapakan yung gas. pero pag naka idle naman ok lang naman.
- Apr 2010
- 268
August 12th, 2013 02:27 PM #5Fuel pump malamang faulty na. Hanap ka ng reputable mechanic sir. Check with nissan forumers.
Peace out!
August 12th, 2013 04:09 PM #6
Mahirap humila? Does the RPM rev freely at neutral? When you're running at gear, nahihirapan to go over a certain RPM? If so, try to check and clean the MAF sensor.
August 12th, 2013 05:12 PM #7
Try checking baka ikaw yung kapit-bahay nung sa kabilang thread tapos nilagyan ng patatas or kamote tambutso mo.
- Aug 2013
- 3
August 12th, 2013 06:31 PM #8
- Dec 2012
- 304
August 14th, 2013 09:37 AM #9kapag tinatapakan mo yung gas, nagrerev ba yung engine?
had an issue with my sentra, hindi nagrerev kahit tapakan yung gas pedal while driving especially sa inclined road. found out, it was the fuel system wiring ang faulty. maluwag yung harness sa may distributor kaya hindi nagrereact ang fuel pump
- Dec 2012
- 304
August 15th, 2013 10:44 AM #10i spoke too soon. had the problem again. engine won't rev past 1700 RPM when running. kapag idle no problem sa pag rev.
still observing pa.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
