Results 1 to 9 of 9
April 29th, 2008 09:17 AM #1
natanggal ang oil cap while running, ano ba ang epekto nito? mga at least 20 kms na ang natakbo nalaman na lang pagdating sa bahay.mga 1 cm na lang sa dip stick ang natira. tumalsik sa engine bay ang oil.
April 29th, 2008 09:21 AM #2
Other than a mess nothing really unless you ran it out of oil. Just clean the engine bay and replace the oil you lost.
April 29th, 2008 09:27 AM #3
^^^ditto, out of curiosity bakit naman natanggal? if you just had a change oil and the mechanic or someone forget to tighten it then go back there and let them pay for the new oils...
April 29th, 2008 10:11 AM #4
tama sila, theres no effect sa engine naman yun, basta within the levels naman oil... it should be fine. bili na lang ng degreaser para malinis ng husto.
April 29th, 2008 01:02 PM #5
Minsan may failure din sa oil cap mismo kaya kumakalas mag-isa. Bihira mangyari yan pero nangyayari sya.
April 29th, 2008 03:47 PM #6
April 29th, 2008 04:30 PM #7
sa lancer na box type na experience ko na ito. ang oil cap kasi hold lang ng isang strip of metal na secured by screw, natangall ang screw kaya nahulog ang oil cap. pero hindi naman nagkalat ang oil sa engine bay, just to make sure inalis ang valve cover at tinangal ang na hulog na screw.? 1cm na lang sa dip stick ang oil hindi ba umilaw ang oil warning light sa dashboard?
April 30th, 2008 08:54 AM #9
Use engine degreaser on selected areas para luminis di naman siguro masisira ang engine mo kasi may oil pa naman at malapit lang naman pero oil in the engine bay can cause some parts to poor performance such as belts and can damage hoses or poor contact sa wirings
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
