Results 1 to 4 of 4
- May 2006
- 41
November 21st, 2011 07:45 PM #1Hi guys may idea kayo kasi nanginginig yung Fx namin after ipa tuneup. Pinalitan is spark plug contact point condenser, change oil and oil filter, air filter. After nun lalo nagkaproblema ata yung makina ng kotse.... San po ba pwede pagawa yung ganun? And may idea po ba kayo kng ano mga cause neto? Dati bago pa tuneup mas ok pa eh. Yun lng medyo matagal na di na tuneup kasi yun.
- Nov 2005
- 255
November 22nd, 2011 09:45 AM #2pa-check mo muna sir yung bagong kabit na spark plug. baka nakadikit yung gap para sa spark.
HTH
November 23rd, 2011 12:58 PM #3
check the spark plug type, heat range and gap. i would assume you have a four cylinder engine. since the breaker points have been replaced, check the points gap (points dwell). haven't done points type since the late '70's but check the gap at its widest opening is usually 0.020 of an inch or adjust the points dwell angle to around 52 degrees. check the idle speed, vacuum advance and centrifugal advance settings. set the spark plug gaps to about 1.1mm (0.039- 0.041 thousandths of an inch)
don't forget to check the fuel delivery system, as part of the traditional tune up, the carburetor idle mixture, base idle speed, fast idle speed and the main metering jet/s be cleaned or adjusted. the pcv valve cleaned or replaced
- May 2006
- 41
November 24th, 2011 08:32 PM #4may mga suggested shops po ba kayo sa manila? sa may paco or sa binondo?
Xiaomi E-Car
