Results 1 to 8 of 8
- Nov 2010
- 13
November 18th, 2010 09:30 PM #1Hi! Hope you could help me guys! Ask ko lang baka may idea kayo. Laging namamatayan yung carburator engine ko, Nissan Series 4. Kahit naka neutral namamatayan kaya dapat mong tapakan ang gas para di mamatay ang makina. Pinalinis ko na din ang carb at naitiming na din ang timing chain ko. Still ganun pa din. Hope you could help me. Francis
November 18th, 2010 09:44 PM #2
What gasoline are you using? Is it a E10 gasoline?
Check your carb if it needs adjusting or even replacing the carb jets.
E10 gasoline and carbs generally don't mix.
For more info, go to this thread: http://tsikot.yehey.com/forums/showthread.php?t=60945
November 18th, 2010 09:54 PM #3
ung distributor mo di ba loose? alam ko wala nang ignition coil yan...
- Jan 2005
- 445
November 18th, 2010 11:46 PM #4have you tried revving the engine (while in neutral) to isolate if the problem is at low or at high rpm?
- Nov 2010
- 13
November 20th, 2010 08:33 AM #5XCS, Gold, and Super premium lang ang lagi kong kinakarga na gas. Bagong linis din ang carb ko. Nagstart eto nung nagpapalit ako ng clutch. I've tried sa iba't ibang mechanic na. Nagagawa nila pero bumabalik yung sira after few days. Namamatayan ako kahit naka neutral. Even tumatakbo sasakyan pababa na naka neutral ako kasi may humps ahead, pagsampa sa humps patay na makina.
1500 carb ang makina ng Nissan Series 4 ang car ko.
Help me guys pls.
- Oct 2008
- 85
- Jan 2005
- 445
November 20th, 2010 02:20 PM #7SO sa Idle sya namamatay...
I think you should replace your fuel filter and re-clean the carb, dapat pag nililinisan ang carb may compressed air na ginagamit.
Another thing, check mo ung fuel shut off solinoid ng carb baka loose ang connection.
Balitaan mo kami.
- Nov 2009
- 456
November 20th, 2010 04:25 PM #8
