Results 1 to 8 of 8
    Hi! Hope you could help me guys! Ask ko lang baka may idea kayo. Laging namamatayan yung carburator engine ko, Nissan Series 4. Kahit naka neutral namamatayan kaya dapat mong tapakan ang gas para di mamatay ang makina. Pinalinis ko na din ang carb at naitiming na din ang timing chain ko. Still ganun pa din. Hope you could help me. Francis
    What gasoline are you using? Is it a E10 gasoline?
    Check your carb if it needs adjusting or even replacing the carb jets.
    E10 gasoline and carbs generally don't mix.
    For more info, go to this thread: http://tsikot.yehey.com/forums/showthread.php?t=60945
  3. #3
    ung distributor mo di ba loose? alam ko wala nang ignition coil yan...
    have you tried revving the engine (while in neutral) to isolate if the problem is at low or at high rpm?
    XCS, Gold, and Super premium lang ang lagi kong kinakarga na gas. Bagong linis din ang carb ko. Nagstart eto nung nagpapalit ako ng clutch. I've tried sa iba't ibang mechanic na. Nagagawa nila pero bumabalik yung sira after few days. Namamatayan ako kahit naka neutral. Even tumatakbo sasakyan pababa na naka neutral ako kasi may humps ahead, pagsampa sa humps patay na makina.
    1500 carb ang makina ng Nissan Series 4 ang car ko.
    Help me guys pls.
    Oct 2008
    have you checked the fuel filter?
    SO sa Idle sya namamatay...
    I think you should replace your fuel filter and re-clean the carb, dapat pag nililinisan ang carb may compressed air na ginagamit.
    Another thing, check mo ung fuel shut off solinoid ng carb baka loose ang connection.
    Balitaan mo kami.
    Quote Originally Posted by francismec View Post
    Baka may sensor or electrical connection na hindi naikabit after maassemble uli ang clutch.
Engine losses power even neutral
