Results 1 to 10 of 34
- 51
April 26th, 2008 12:10 AM #1i have a 1993 toyota xe. i just put a new headgasket head wasnt warped, new piston ring and replaced valve seal, runs great but smokes alot from exhaust white smoke. no over heating no rough idle no check engine light or eml light. doesnt start to smoke until about 3 -5 minutes after i start the car and let it idle. pls help me mga bro i really dont know what to do.
April 26th, 2008 12:32 AM #2
Question : Who did the service?
You have just put in a new headgasket, Are you a mechanic?
Have you read your references?Last edited by mark_t; April 26th, 2008 at 12:38 AM.
- 51
April 26th, 2008 12:41 AM #3yung mekaniko ko po ang nagpalit ng piston ring tska ung pinagpalitan nya eh hnd nmn putol valve sezl pinapalitan ko nrin pati spark plug, pag inistart ko ung kotse wala p usok pero habang tumataas n ung temp ngkakaroon n ng usok pero hanggang kalahati lng temp nya, bkit kya umuusok prin car ko?
- 51
April 26th, 2008 12:58 AM #5matagal n po syang mekaniko dun n nga po sya tumanda eh, ngwwork sya s huge auto shop company ung mga insured n kotse gngawa nila, im hoping n carbon deposit lang ung cause ng usok, khapon nga lng pala ginawa ung kotse ko kya hnd ko p nbbreak in
April 26th, 2008 01:15 AM #6
most probably palpak ang gawa...kasi i had white smoke din few weeks ago and valve seals lang pinalitan kasi ok pa piston rings and so far ok na, wala ng white smoke
- 51
April 26th, 2008 01:26 AM #7pero db dpat kng palpak ung gawa, pagstart plang my usok n pero wala eh mag-iinit muna ung makina mga 3-5 minutes tpos, un uusok n
April 26th, 2008 02:41 AM #8
hey bro, its either the Valve Seal was not installed properly (may ilan siguro na hindi maayos ang pag install) OR the Piston Rings were not clocked in the right position.
also, bakit pinalitan ang piston rings?? may blowby ba yung engine before hand??
aite, peace.
April 26th, 2008 02:54 AM #9
Bad valve seal or bad head gasket produce a passage for the antifreeze to pass from the capillaries into combustion chamber. Maaring nagtipid ka sa mga gasket kaya hindi maganda ang outcome sa pagkagawa. No offense, its only a CeNts.
Its easy to check if you have bad head gasket, all you need is air compressor and air noozle. Remove one of your sparkplug and the radiator cap fill the radiator w/ water and pump air in the sparkplug hole(do not put radiator cap) repeat with all the cylinder and watch for bubbles coming up into radiator. If bubbles are present the head gasket are blown and must be replaced.
April 26th, 2008 07:00 AM #10
Flush your muffler with water. Its possible that oil is still present in the exhaust system. Are you still in break in? Style of break in?
of course! the former was more enlightening than reading the Holy Book. mom loved the Ten...
Traffic!
