Can you clarify please, TS? When you said "pag iniistart di tumutuloy" do you mean when you turn the key nothing happens, or when you turn the key, it makes the starting sound then it dies?
If it is the first, you might want to check your fuses and make sure these are not burnt, and that these are properly seated.
If it is the second, there are two possibilities: your battery is dying and cannot provide adequate start up power; or, there's a clog in your fuel line or fuel filter. You might want to try to crank your vehicle... check your manual for the proper process for your specific brand and model.
Have you done any other diagnostic tests? Have you tried turning on your wipers? Try turning it on to see if it swipes normally or if it is oddly slower than usual. Such would indicate low battery power or an issue with your electricals. Also check your spark plugs.
By the way, what is the brand and model of your vehicle? Please give us as much detail about your car to help in the diagnostics.
