Hi sirs! I would like to seek for your advise and inputs regarding the problem of my Ford lynx ghia 1.6 (gen 1) manual transmission. Trying to save as much as possible from buying parts and testing it and also the labor, since the culprit could not be identified easily.
Symptom:
Misfire
The misfire (palya) can be felt when the car is running since sobra po yung pagjejerk ng sasakyan.
Dinig din po to since nakafreeflow muffler yung kotse, may times na napuputol yung tunog nya.
The car runs smoothly pag malamig pa makina, but when it gets hot, nagsstart na sya magmisfire.
No erratic idling and the car never stalled. Its almost 2 months na ganito po sakit ng kotse ko.
History:
The engine bay was infested by rats. Rat droppings were present in the engine specifically in the coils. These caused the coils to warped and eventually failed resulting to misfires. At first, since di pa nakabili ng parts, pinalinis ko lang spark plugs at nilinis din ng mechanic yung "servo". Pero ganun padin, but these time parang tumigas tunog makina and i suspected baka di lang nakuha tamang idle. A week later pinalitan ko na ignition coil, coil packs and spark plugs, cleaned maf sensor and crankshaft sensor but to no avail. Same symptoms padin po ang nagmamanifest.
Planning to take it to CASA for scanning, unfortunately, wala na daw OBD scan mga ford CASAs. Kaya, if you can also recommend po shops na nagreread ng OBD. My area is Evangelista St, Makati.
Any inputs or advise will be appreciated. Thanks!![]()
