Results 2,251 to 2,260 of 6585
- Mar 2014
- 21
March 22nd, 2014 05:05 PM #2251mga sir question lang.. read here or another post na 'some' filters in ACE hardware are not 100% authentic? ang price range kasi na nakikita ko for a typical Vic C111 (Megamall, SM Tiendesitas) is around 250-ish. any support kung totoo na hindi totoong VIC filters ung asa ace?
second question ko po eh, if I bring my own oil (planning to get Mobil Super 2000) and filter sa gas station, mga magkano ba ang labor only sa change oil?
March 22nd, 2014 05:21 PM #2252
Downside - Higher fuel consumption and slower engine response
It's not true that old engines require more viscous oil. Old engines WITH worn out seals and gaskets will leak oil. When engines start to leak, your options are to replace the seals and gaskets, or if you don't have the budget for the repairs, use a more viscous oil to prevent the oil from leaking.
March 22nd, 2014 05:40 PM #2253
March 22nd, 2014 07:55 PM #2254
Thick oil or sticky oil or less slippery oil doesnt prevent oil leak it just limit it to a more manageable compared to thin oil
Posted via Tsikot Mobile AppLast edited by kisshmet; March 22nd, 2014 at 07:58 PM.
March 22nd, 2014 08:17 PM #2255
The base oil itself wont, but the "high mileage" oil additives that are specially formulated to restore and rejuvenate hardened oil seals will.
Mineral oils, specially higher SAE grade mineral oils have lower capillary action and will have a harder time sipping thru gaps on worn out seals and gaskets.
March 23rd, 2014 12:54 AM #2256
- May 2012
- 372
March 23rd, 2014 03:42 AM #2257Im currently using mobil 1 super 2000 10w40, i should say my engine is running good.
How about shell hx7 5w40? I saw it in shell station and its priced 1300 pesos. Any users here?
Sent from my iPod touch using Tapatalk
- Mar 2012
- 20
March 24th, 2014 10:11 AM #2258i am a user of shell hx7 5w40 on our 2007 altis. although nakaka-isang change oil pa lang ako using this oil dahil kakabili lang namin nung altis last year. shell hx5 kasi yung gamit sa pajero namin. ok naman sya kaya shell na lang din ginamit ko dun sa altis.hehe
so far ok naman. satisfied naman ako sa responsive ng engine. napaparanoid lang ako dahil sa vic ang gamit ko na oil filter. walang mabiling baldwin sa las pinas. kahit na yung bosch e wala din.
pero sa next change oil namin e i will try another oil. nagmahal na kasi yung hx7 sa area namin. hahanap pa ako ng mura na ok.
- Nov 2013
- 2,077
March 24th, 2014 01:20 PM #2259sirs saan toyota casa ba pwede magdala nang sariling oil and filter kapag PMS? i'm from bf homes paranaque
March 24th, 2014 01:32 PM #2260
