Page 127 of 200 FirstFirst ... 2777117123124125126127128129130131137177 ... LastLast
Results 2,521 to 2,540 of 6586
    Jan 2009
    Quote Originally Posted by radz15 View Post
    Mga boss totoong bang recommend atleast 10k mileage bago gumamit ng fully synthetic oil
    Not true. Use the best oil you can afford (or allowed by your dealer) on your first oil change.
    Apr 2014
    10k or 1 year usually sa FS oils.
    Mar 2012
    anyone tried a pertamina engine oil? medyo hindi kasi ako familiar but sa other asian countries, sikat raw ito...
    Jun 2014
    I use my car everyday at an average of 50-55km mileage. Nearing for an oil change at 45,000kms. Currently using zic a+ with baldwin filter. Before i used zic a semi-synthetic. Nag change ako sa zic a+ kasi sabi sakin mas maganda hatak ng makina. Pero minimal lang pala. Still thinking if i'm going back to semi-synthetic and change oil every 5k or mag fully synthetic ulit ako. Zic a+ parin gagamitin ko. I also want to try diesel engine oils like zic rv, zic up or caltex delo gold. Hindi parin ako makadecide anu ang mas ok. Please give some inputs kung anu mas ok. For vios gen2 pala ito. Thanks
    Jul 2015
    Maganda ang zic na brand. I think top maker ng group 3 base in the world.
    Yung fully synthetic kasi pwede group 3 or group 4 pao. So allowed imarket as fully synthetic kahit group 3.
    Mga binebenta engine oil sa casa are group 3 fully synthetic. Even sa ace hardware. Mabibilang lang group 4
    Negligible na din sa performance. Nagsasayang lang ng pera sa group 4 sa sobra mahal.
    Ang importante tama viscosity. Jan lang kayo magkamali pangit takbo kotse.
    Jul 2015
    Quote Originally Posted by _incubus19 View Post
    If zic gamit ka A+ 5w30, XQ 5w40 or RV+ 5w30
    Sa delo gold puro 15w40 sa pinas pangit takbo. Kung kaya mo padala mga 5w30 na delo from abroad eh mas ok
    Jun 2014
    Quote Originally Posted by amoyligo View Post
    Un zic a+ na gamit ko ngayon is 5w30 and un previous na zic a (semi-synthetic) 10w40. Ask ko lang anu ang difference ng zic RV and zic XQ? Pag dating sa pang diesel engine oils no idea talaga ako.
    Zic rv is their mid end oil. Zic xq is their top of the line oil. Some zic xq have grp4 while zic rv is only grp3.
    Jun 2014
    Noted. Thanks sir.
    Jul 2015
    Yung XQ 5w40 SM/CF mas better for gasoline engine.
    For diesel engine mas ok pa din CI-4 CH-4
    Jun 2014
    Thanks sir.
    Aug 2015
    Mejo OT mga sirs:
    Me konti akong bloopers di kami nagkaintindihan nung sa changeoil ko, later on 20w-50 ung naikarga sa 07 altis ko. Recommended is anywhere bet 5 to 20w30. Is it safe na sa next pms nalang palitan or palitan ko na now? Less than 100kms palang tinakbo, ala pa naman issue. Ano opinion nyo mga boss.
    Jul 2015
    Sayang naman kung papalitan mo agad. Gamitin mo hanggang 3,000 to 5,000 kms.
    Yun nga lang pigil yun takbo.
    Mar 2012
    Pwede rin na hanggang 1k lang tapos change oil ulit, consider mo na lang as engine flush yung thick oil.
    Jun 2015
    Good morning, mga bossing ilang liters ba ATF kailangan ng Montero GLS papalitan ko na sana ATF ko at hanap ako ng magandang brand na ATF like Red Line or RP. Salamat
    Aug 2015
    Thanks mga sir ha. Yun naman din plano ko w/c is next pms nalang palitan. Sayang din. Baka lang kasi may bad effect kahit 5 months lang.
    Hi admin, pardon for barging-in. cant open a new thread for now.
    I just bought a 2007 Vios 1.5G manual tranny with an odometer reading of 78k. Since this is my first car, im a NEWBIE when it comes to car maintenance. Just want to know what type/brand of coolant (coolant compartment is almost empty) i need to add and type/brand of engine oil (current color is amber brown) to use. Kindly include type/brand of steering wheel and brake fluid you recommend to use. Former owner of the car is already on other country that's why I cant get advise/feedback from him.
    Thank you very much for your feedbacks to come.
    P.S. You may put this topic on proper thread if you may..
    Aug 2015
    Quote Originally Posted by Jeffrey Gapuz View Post
    para di ka mahirapan sir toyota bilhin mo. pwede mo naman ipalagay sa labas. pero if you want accurate info nasa owner's manual naman ito. pero wait naten ibang owners ng same vios model para mag ka idea kayo sa alternatives.
    Apr 2012
    Regarding sa coolant, use toyota pre mixed coolant. And make sure na warmed up na engine mo pag nag check ka. Dont use plain water alone.
    Steering fluid? Hindi pa ba EPS and 2007 model? Dexron 3 atf should be fine as PS fluid. Brake fluid naman any brand will do basta DOT3. I suggest caltex or shell or mag1.
    Enine oil any will do. 15w40 mineral, 5w30/10w30 for fully synthetic.
    Better post you next queries sa Vios thread
    Mar 2012
    check mo rin mabuti yung coolant compartment, kasi sa car ko, not toyota, mahaba siya so baka akala mo halos ubos na kasi malalim ang full level indicator.
Mineral , semi synthetic or fully synthetic?
