Page 125 of 200 FirstFirst ... 2575115121122123124125126127128129135175 ... LastLast
Results 2,481 to 2,500 of 6586
    Mar 2015
    Why is it there very few brands that offer 10w/30? Been looking for this and it seems Mag brand only offers this. Is this brand worth trying?
    Mar 2012
    I'm using mag 5w30 FS right now, but I feel that Honda SS 5w30 is better. Both are priced at 1,9++.00/4 liters.
    Jul 2015
    The lower the viscosity mas expensive usually. Usually nagooffer ganyan malalaki company like castrol zic mobil valvoline idemitsu
    As always check mo details nakaindicate like api and saan gawa.
    Ang dami kasi incomplete details halatang repack.
    Mar 2015
    Quote Originally Posted by amoyligo View Post
    imageuploadedbytsikot-forums1443939737.526477.jpgimageuploadedbytsikot-forums1443939758.076396.jpgimageuploadedbytsikot-forums1443939789.159543.jpgimageuploadedbytsikot-forums1443939818.510251.jpg
    Which of these is the better oil sir? Would really like to try a 10w/30 coz i've been using shell ultra 5w/40 ever since. Thank you!
    Jul 2015
    1st and 2nd photo hindi ko mabasa.
    3rd and 4th maganda rating.
    Magkano price?
    Mar 2015
    Magkano price?
    imageuploadedbytsikot-forums1443941693.516384.jpgimageuploadedbytsikot-forums1443941709.519920.jpgimageuploadedbytsikot-forums1443941731.182922.jpgimageuploadedbytsikot-forums1443941745.749809.jpg
    Sir nasa 500+ pricing po mga yan per liter. Thanks! May dagdag pa po ako dito. Yun 3 at 4 bago po.
    Quote Originally Posted by maki mi View Post
    If the honda ss is sl rated. It will feel better.
    Mar 2012
    Bro Stock, both are SN rated, mas magaan ang hatak sa Honda SS vs Mag1 FS.
    Quote Originally Posted by SkyFlakes88 View Post
    Mag1 full synthetic-fmx 5w30 or 10w30 has one of the best additives. I would get that if all are priced equally.
    Mar 2015
    Thank you sir! [emoji4] my manual recommends 10w/30 so i'd like to try one. Been on 5w/40 and wanna feel if there's a difference sir. Thanks again!
    What is that dexos certified bottle? Some dexos1 bottles are semi synthetic.
    The new versions of dexos next year or 2017 will be required to be fully synthetic.
    Jul 2014
    Mag1 FS SAE 5W30 API SN
    P1,505 per gallon.
    Mar 2012
    Ano kaya kaibahan nito dun sa nasa transparent na container? Pareho ng specs, but yung transaparent ay nasa 19++.++/4L.
    Quote Originally Posted by Mask Rider Blac View Post
    P1,505 per gallon.
    P1,505 per gallon.
    Jul 2014
    Ung nakita kong clear containers ay 1 liter lang. Hindi pko nakakita ng 1 gallon clear container. Nasa P2K+- price sa Ace pero P1,505 sa banawe. Specific for gas engines 'to. Ung for diesel/gas engines, mas mahal nasa P2K.
    Apr 2014
    Ace dito sa davao 2K+ pa rin benta ng mag1.
    Mar 2005
    P1,505 per gallon.
    Naka kuha din ako neto nung sale sa landmark trinoma naka 10% off pa. Will post feedback pag nakapag change oil na ako.
    P1,505 per gallon.
    Honda oil has higher moly sa US and even if theyre 5w30, some oils at operating temperatures are lighter.
    Mar 2012
    I googled moly, so that's the reason why it feels different. No more experimenting for me from now on, i'll just stick to the oil my engine likes
    Quote Originally Posted by StockEngingine View Post
    Jul 2015
    Kung mga CI-4/SL oil pa ZDDP yan.
    Pero mga newer oil Moly na.
    Ako personally mas ok pa din zddp dahil dual purpose. Hindi lang daw friendly sa catalytic converter.
    The "dexos 1" spec will be relatively rigorous, designed to enhance engine protection AND engine oil longevity. As a result, for an oil to meet the "dexos 1" spec, it will likely be necessary for oil manufacturers to utilize primarily Group III and/or Group IV basestocks in the formulation, certainly adding considerably to the cost of the oil, thus raising the price for the end user. In essence, primarily synthetic oils and high quality synthetic blends will be able to meet the spec.
    Additionally adding to the cost of the oil will be the inclusion of molybdenum in the spec for it's anti-wear properties. Although ZDDP is extremely cheap (and effective) as an anti-wear additive (while also working as an anti-oxidant in the oil), molybdenum is incredibly expensive (in the order of 50 times more expensive) and does NOT also act as an anti-oxidant - thereby requiring the use of additional additives to serve the purpose.
    Yun clear containers from US market na imported. Im sure they are good.
    The others I do no know. Meron na local distributor and you can probably ask them if they locally bottle the oils.
Mineral , semi synthetic or fully synthetic?
