Page 119 of 200 FirstFirst ... 1969109115116117118119120121122123129169 ... LastLast
Results 2,361 to 2,380 of 6586
    Aug 2015
    Alin po ba mas maganda sa dalawa? Mobil 1 TDT 5w-40 or Mobil Delvac 1 5w-40? Medyo nalilito po kasi ako sa dalawa,,,
    Quote Originally Posted by Grey14 View Post
    Some say its the same formulation. Go for the cheaper one.
    Aug 2015
    Ok po sir, ill buy nlng po cguro yung mobil 1 TDT, mas cheaper than delvac,. Hehe, thanks alot po sir!
    Mobil1 Delvc ang mas maganda pero okay na din Mobil1 TDT if cheaper gusto mo. Lalo na kung very 5,000kms palit mo oil.
    Quote Originally Posted by midnytwarrior View Post
    Sir, ask ko lang about yan sa Dexos rating. Diba po requirement sya ng General Motors sa mga oils na gagamitin sa engines nila? Or requirement na rin ba sya ng lahat ng manufacturer?
    Thanks
    Thanks
    Its required for chevrolet/gmc vehicles. Its a more stringent requirement compared to ap-sn. Its at least semi synthetic to fully synthetic. No conventional oil will pass dexos1 certification.
    If the engine oil bottle like the new zic a+ doesnt have "meets or exceeds dexos1" statement on it and only contains api-sn/gf-5 then its an api-sn oil/gf-5 only. There are other versions of zic a+ that meet dexos1. But certainly not the bottle of zic a+ that was shown earlier nin this thread.
    Apr 2014
    Ah Ok Sir, thanks po.
    So basically GM vehicles lang at wala sya significance sa ibang manufacturers.
    Thanks po ulit
    Thanks po ulit
    Which Delvac1 product pala? Delvac1 5w40 or Delvac1 ESP 5w40?
    Aug 2015
    Yung Delvac1 ESP sir,. By the way nakabili na po ako kanina ng Mobil1 TDT, 440 pesos per 1 US Qt. Nakamenos kahit papaano,. Hehe,.
    Delvac1 esp 5w40 = mobil1 tdt 5w40
    Fyi "Delvac1 5w40" is the top of the line delvac1 hehehe. The "delvac1 esp 5w40" version is different.
    Good purchase nonetheless. Amazing price!
    Apr 2012
    Delvac 1 5W40 is CI-4+ while Mobil 1 TDT C-4 yata?
    Pero ang mura niyan. San ka nakabili?
    Like I said Mobil1 tdt 5w40 is different from delvac1 5w40 but it is the same as delvac1 esp 5w40.
    Aug 2010
    just want to give my feedback on delo 400.
    change oil 2 weeks ago using delo 400. drove 100km since....
    I say very disappointing. hindi madulas, mas umingay yung engine.
    problem is... there's still 4900km to go
    i'll give it 2/10
    Quote Originally Posted by trucker111 View Post
    i'll give it 2/10
    may naiwan pa na oil from your previous oil change. give it another oil change to feel the difference.
    Normally pag sagad ang gamit ng sasakyan, pina flush ko ng mumurahing oil bago ilagayj yung oil na gagamitin ko para matangal yung lumang oil.
    Aug 2010
    i saw how my mechanic drained the oil pan.
    he put 2 liters of diesel to the engine to dilute the oil before draining. then used air compressor.
    mga 2 hrs after draining the pan, (simut na simut) bago kinarga yung delo 400.
    1st time ko lang na experience yung ganyan. been using top1 sdo before trying delo.
    Apr 2014
    Sana hinde pina start yun engine after ilagay yun diesel. Nakakpalambot kasi ng mga seals yan. At sana yun air compressor meron air-water separator.
    Jul 2015
    i'll give it 2/10
    Sabi ko sa inyo overrated ang delo oil. Ginamit ko yan sa 12 rent a car montero. Pati sa taxi ng family business at ng relatives. Ilan beses namin inulit dahil mura din bigay pero wala talaga ang gaspang ng takbo. Same with shell gaspang na pigil takbo.
    So its better to try the oil and compare.
    Aug 2010
    Quote Originally Posted by amoyligo View Post
    I think that's the right adjective... magaspang ang takbo.
    nakakainis din kasi lumakas ang vibration.
    4850kms to go
    malamang mga 3000kms palit na.
    will probably try zic x7 10w30 next unless somebody will give negative feedback on this
    4850kms to go
    Sir, i have the same oil for my upcoming change oil this coming weekend. first time to try these formulation of zic. Dati Zic RV ako and Top 1 SDO. I believe your ride is a TCI starex?
    Mar 2015
    Sir since you have quite an experience with oils could you recommend what oil can i try with my ride po? I am now using shell helix 5w/40 in my car. What other brands can you recommend po that is better for gas fed engines sir? Thank you [emoji4]
Mineral , semi synthetic or fully synthetic?
