Results 2,681 to 2,690 of 6585
August 2nd, 2014 01:35 PM #2681
- Sep 2013
- 630
August 2nd, 2014 01:47 PM #2682^
Nakakaconfuse yang motul crdi specific. Naka-indicate API SN pero hindi ko makita yung C rating for diesel.
Yung API SN hangang 5,000 to 7,500 kms lang palitan ko na. Around sa ganyan kms check nyo pag itim at mabuhangin/sandy feeling palitan nyo na oil
- Aug 2013
- 475
August 3rd, 2014 08:54 AM #2683with all due respect bro, based on experience, hindi sluggish o "mabigat" yung feel ng makina kapag 15W-40 sa gasoline engine.
gamit ko ganitong viscosity sa Vios (2NZ) tska sa Corolla (2E). sa totoo lang, hiyang na hiyang sila dito compared sa 5W-40 Toyota Fully synth.
mga nagamit kong 15W-40 so far ay Mobil Delvac MX at Delo Gold Multi, pero mas hiyang yung dalawang kotse sa Delo Gold Multi.
pareho silang naka Baldwin BT223.
August 3rd, 2014 09:34 AM #2684
at normal operating temperature nang engine(hot), most oils have the same viscosity...
the dragging feeling is only at start up dahil 15w ang starting pero once the temp of the engine is hot,
same viscosity is achieved for most oils,
the fuel economy is base on the oils higher viscosity rating, the higher viscosity rating the better your FC will be.
150 viscosity will be more fuel efficient compared to 135 viscosity at a .5% difference in fuel consumption at best.
if you want oils for tight tolerance engines, with better FC, and no dragging feeling on start up, 0W-30 would be ideal.
- Sep 2013
- 630
August 3rd, 2014 12:04 PM #2685Ang kotse ni number001 eh isang 1999 civic na halos pareha sa kotse ko. Nagkaiba lang sa taon. Pag member ka sa honda forum mababasa mo overwhelming majority sluggish ang experience.
Pag nagback read ka eh mababasa mo inadvise ko na hiyang 15w40 sa toyota engine. Ang pinagamit ko sa 2011 altis ng barkada ko delo gold ultra. Ang tahimik ng engine sa idle.
Sa car manual ng toyota advisable ang 15w40. Even the crazy "diesel viscosity" 20w50. For me masyado na malapot yan.
But for honda and subaru do not use 15w40.Last edited by chookchakchenes; August 3rd, 2014 at 12:08 PM.
- Aug 2013
- 475
August 3rd, 2014 02:11 PM #2686salamat sa clarification paps.
share ko lang din, race car ng kaibigan ko, delo gold ultra gamit niya, '98 Civic SIR na naka typeR internals (B16b). yung pang daily naman niya na EF civic na PH12, delo gold multi. ang kwento niya kasi sakin, medyo madali daw mag leak kapag XW-30 ang gamit niyang viscosiy sa mga Honda niya o baka tamad lang siya magpa gawa ng oil seals.
pansin niya kapag naka 15W-40 siya sa SIR niya, mas stable oil pressure.
- Sep 2013
- 630
August 3rd, 2014 05:52 PM #2687^
Kailangan lang ipagawa ng friend mo yung seals para hindi magleak. Napansin ko kasi sa mga leak kahit 20w50 (enoc brand ) gamit ko nung year 2007-2008 eh tumagas sa lancer ko kaya palit valve cover gasket.
Sumikat yung delo gold sa mga kumakarera naka civic s.i.r , toyota big body, nissan box type and B13 (pero ako na civic vti, pacruising-crusing lang parang may pumipigil sa arangkada pag 15w40 gamit ko. Hindi smooth yung takbo.)
- Jun 2011
- 130
August 3rd, 2014 07:20 PM #2688
August 4th, 2014 11:39 AM #2689
August 4th, 2014 11:42 AM #2690
