Results 1 to 6 of 6
    Toyota Corolla GLI 1994, Problem ko po is pag namatayan po ako ng engine, ang hirap napo mag start. walang redondo pag nag try ako mag start uli.
    Maraming Salamat po,
    sana nag kwento ka pa konti para mas madali ivisualize yung problem . baka kasi engine trouble na talaga yan..
    anyways, process of elimination, don ka muna sa mas mura at madali gawin...
    check/do the following...
    1. battery, ok pa ba sya? if no, replace
    2. if yes, yung alternator ba nagkakarga?
    3. if yes, check the starter, me clicking sound (solenoid) ka ba nadidinig?
    4. if yes, sure kaba na maayos/malinis starter commutator mo. ok pa ba carbon?
    iyan muna bro check mo, start mo diagnose muna battery then let us know..
    keep us posted... regards
    Boss, ayos naman po ang battery at alternator. pag unang start one click start agad po sya, kahit paulit ulit na mag start ok naman po sya. pag namatayan lang po ako ng engine saka lang po mahirap mag start. pag nag start po ako mga ilang beses walang click, try lang ulit meron na ako maririnig na click hanggang sa mag start na po sya. medyo kakaiba nga po ang sakit nitong auto ko.
    Maraming salamat po sa reply
    it could be wiring problem sa starting system mo... lets think it that way muna before concluding that its an engine problem...
    get a multitester o 12v light. connect it to your starter don sa line (wire) galing ng ignition switch.. everytime nag switch ka to "start", dapat mag light yung bulb of course. if not, it simply confirms na electrical ang problem mo... possible causes could be the wires itself, the fuse, sockets, and the ignition switch...
    check the fuse and sockets first kung maluwag or madumi...
    if ok naman sya, disassemble the ignition switch, dumudumi din kasi yon at sometimes nagtututong especially don sa madalas mabaha or me moisture sa loob ng sasakyan pag umuulan...
    pag ok yung switch at ganon pa din me occasion na ayaw mag start, i bypass mo muna yung wire from switch to starter and observe.
    personally, i think electrical problem lang yan.... kailangan mo lang magtyaga i trouble shoot... regards
    Boss meron po ba kayong ma rerecommend na talyer or shop dto sa paranaque.
    Quote Originally Posted by cool_totoybibo View Post
    sorry, wala ako alam dyan sa area mo. maybe other members could help you...
Mga Boss Patulong po Hirap mag start
