Results 1 to 6 of 6
- Jul 2006
- 48
December 28th, 2008 04:56 PM #1napansin ko this morning na parang may langis (di naman tagas) malapit dun sa ditributor. Dun kung saan nakaattache yung distributor sa engine. Delikado po ba ito? Para rin kase nababawasan yung oil level pero di naman grabe. Paano kaya to maremedyuhan, gasket lang kaya papalitan?
TIA
God Bless
December 29th, 2008 12:57 PM #2
ano ba ang ride mo? kasi sa civic merong rubber seal ito at ganyan din ang nangyari sa aki pero ang ginawa ko hinugot ko na lang ang distributor at nilagyan ng rtv sealant ok na
December 29th, 2008 03:11 PM #3
Small oil leak, possibly worn seal. Not a significant leak if you keep an eye on the oil level. Replace the seal when you have time. Don't forget to have timing done, I think this repair will require timing to be done since the distributor will be removed.
- Feb 2008
- 577
January 4th, 2009 09:15 AM #4chances are its the o-ring if its the distributor side. kung cam gear side, oil seal. tigthen bolts to specified torque always
January 4th, 2009 11:11 AM #5
Spyghost is right.
There is 1 bolt and a keeper that holds it in place.
First make sure the keeper is straight then tighten it up.
That should fix it
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 15th, 2009 11:59 AM #6there are distributor o-rings and oil seals. replace whichever is leaking.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
