Results 1 to 3 of 3
- Oct 2005
- 32
March 31st, 2006 11:04 PM #1Automatic engine ..while driving ..then approaching a stop light ..RED then stop ...about 2 minutes GREEN .go ....biglang tigil makina ..patay makina then start andar na uli ...any comments ? Stop engine when idle for too long i need to re start it again ..any help?
thanks
- Jul 2005
- 22
April 1st, 2006 01:50 AM #2na experience ko rin yan namatay makina ko. start ko uli and go. ewan ko bakit ganun nangyari. after i replace new batt, Hi tension wires, adjust idle hindi naman na ulit na nangyari yun. check mu idle mu bro, baka yun masyado mababa.
April 1st, 2006 03:42 AM #3
ah..
ang nangyari naman sakin kapag naka-stop (intersection) at naka-apak sa preno..
humihina lahat ng ilaw.. headlights, dash saka sa intrument cluster..
tapos umiilaw din ung mga ABS lights.. (signal nawawalan ng power, pinapatay ng ECU ang ABS)
then pagdating ko sa eastwood, pila sa carpark ganun ulit..
ginawa ko pinatay ko ung makina.. pagstart ko.. ayaw na!!
called for back-up.. jump-started using booster (series) cable..
kinabukasan.. bumili na agad ako battery. wala na prob..hehe
also check for spark plugs (replace if needed), loose batt cable or worst damaged alternator.. kaya di na kumakarga batt.
HTH.
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
