Results 1 to 15 of 15
    Jan 2003
    there was a thread before that you can use delo gold for gas engines. however some commented that delo gold is monograde (sae40) and its not compatible.
    now that theres this 15w-40, is it compatible with gas engine?
    sabi kasi nila e mas maganda cleaning action ng diesel oil than gas engine oil.
    any comments??
    thank you
    Yung officemate ko ganyan pinalagay nya sa Rav4 nya. Mukang wala naman sya reklamo AFAIK.
    May 2005
    thats what the casa is putting in my ride, so its up to par, i guess
    Jan 2003
    docpete,
    whats yur ride?
    Oct 2003
    Yung lancer singkit ko dati, 3 times ako nagpa-change oil na ang pinalit is yung total ng diesel engine oil. Never had any problems with it naman, and sabi ng mekaniko ko ok lang daw yun.
    May DELO na designed for fleet applications. Ewan ko lang kung iyan yun. It will work for gas and diesel engines. So that fleetmasters don't have to stock different oils for the different vehicles in the motorpool.
    diesel engines uses SAE 40 before, now that we have the SAE 15W-40, most diesel engines especially generator sets uses this because it have a higher viscosity than the plain SAE 40. This were formulated to compensate for the increase of temperature of oil wherein the viscosity decreases when oil temperature increases. Ang scenario ng 15W-40, kapag uminit ang oil na ito at bumaba yung viscosity, eksakto pa rin sa viscosity na SAE 40 kasi mataas nga ito. Ang result, tama pa rin ang lubrication at eksakto , but in the case of gasoline engine, sobra taas ng 15W-40 compared sa SAE 30 na pang gasoline/ kung bago engine mo di mo makikita ang effect, pag nagtagal at medyo luma na baka dun mo makita ang negative results. I suggest na hwag gamitin ito kasi pang industrial diesl engine ito ginagamit. Mas maganda kung sundin yung nasa manual.
    Nov 2003
    gas oil for gas engines and diesel oil for diesel engines. what could be simpler?
    http://tsikot.yehey.com/forums/showthread.php?t=4985
    Quote Originally Posted by roydok
    Oil Name : Delo Gold Multigrade
    Blend : Type 2 Base Oil
    Rating : API CH-4, CG-4, SJ
    Viscosity : 15W-40
    Retail Price : P135.00 per liter
    Recommended for what types of Diesel Ride: All including gasoline
    Your service manual should indicate what type of oil to use in particular circumstances. Generally, oil grade is driven by ambient operating conditions. Hence, monograde 40W oil is used when ambient temp is =>40 degrees (like metro manila). multigrade oils like 15W-50 are used for temperate countries. 15W means 15 degrees winter. You need oil with low viscosity for the engine to turn while cold.
    I thought about this when I asked a friend who was in the racing circuit what type of oil he used for his bimmers. His response was Delo Gold 40W. He also mentioned that he changes oil every quarter regardless of km readings. Now you know benefits of frequent oil change.
    Jul 2003
    buhayin ko lang itong thread.
    plano ko mag-change oil before new year and delo gold ang gagamitin ko. confirmed naman sa label for diesel and gasoline engines.
    reasons ko: mura at high detergency
    monograde lang gagamitin ko SAE 40 ata which is ideal sa Pinas. Wala naman daw drastic fluctuation sa temperature natin so wala problema sa monograde basta within the cars specs ayon sa manual.
    any experience on this?
    Okay lang ang Delo gold basta sundin mo lang iyong owners manual ng interval ng change oil.
    Jul 2003
    ok. salamat ng marami!
    this is the oil i've been using on my lancer. so far so good. delo gold multigrade 15w40. and yes, its designed for fleet applications.
    hindi naman kasi ako mileage based kung magchange oil. time based ako. every 3 months oci ko, 4 months ang stretch. diy naman ako lagi magchange oil so no labor charges involved. materials lang and a little time, change oil lang naman.
    as long as pasok sa specs na makina ang langis pwede sya. total cost wise compared to a fully synthetic oil change, true mas mahal ang approach ko, pero i'm always assured na malinis lagi ang langis. unlike kung gagamit ako ng fully synthetic at sasagarin ko to 5000 km. marumi na talaga yung langis. ayoko paabutin sa ganitong stage kaya gumagamit nalang ako ng mas murang langis na laging pinapalitan.
    Jul 2003
    dati kasi every 6 mos ako mag-change oil at hindi pa yun umaabot sa 2,500km dahil bihira gamitin. ngayon araw araw ginagamit kotse pangkaon ng anak ko so balik ako sa every 3 mos (or 5000km whichever comes first).
    ndi naman malayo presyo ng delo gold sa mobil or castrol na usually gingamit ko. mas maganda daw maglinis ng makina dahil sa high detergency. yun lang muna habol ko.
    DIY din ako mag change oil. at nalaman ko na matindi na tagas ng isang oil seal sa valve cover. haayyyy. next time ayun naman.
Delo Gold 15w-40
