Results 1 to 8 of 8
    Nov 2007
    tulong naman po kung pano ko malilinis ang maf sensor ng a32 ko...
    just spray carb cleaner on it. do not touch it.
    Jun 2005
    kung meron kang makitang maf cleaner mas maigi. nilinis ko dati yung isang sr20.
    remove maf, spray from all directions to the "sensor" without any contact, and thats it.
    linis mo na rin throttle body kung kailangan.
    p.s. tagal ng pics ah
    Nov 2007
    parang nakakatakot linisin e. madali lang ba maglinis ng maf sensor? spray lang? ok lang ba matamaan nung cleaner yung filament?
    pano ko naman po malalaman kung need nang linisin din yung throttle body? tsaka pano po yun linisan for an a32?
    May 2007
    If you used the wrong cleaner you will damaged the sensor. Carb and Choke Cleaner is not intended to be used on sensors. A MAF sensor should only be cleaned with material designed for this purpose and carefully follow the instructions.
    You must used MAF sensor cleaner instead. Like this one.
    Product Description The first product specifically developed to clean mass air flow sensors. Increases horsepower & improves air/fuel ratio and MPG. Plastic safe-dries in seconds!
    Product SpecificationsApplications Mass air flow sensors & housing Unit Package Description 16 Ounce Aerosol Generic Description 1 Electronic Cleaner Brand CRC Net Fill 11 Wt Oz UPC Code 0 78254 05110 9 Unit Dimensions-Inches 7.75H x 2.63W x 2.63D Units Per Case 12 Case Dimensions-Inches 8.69H x 8.44W x 11.31D Cases Per Pallet 133 Lbs. Per Case 7 I 2 of 5 Code 30078254051100 Appearance Clear Colorless Liquid Odor Alcohol Base Type Petroleum Distillate/Alcohol Flashpoint - TCC Method <0°F Specific Gravity 0.6699 KB Value 27 Flammability Extremely Flammable Plastic Safe Yes Evaporation Rate 9 Dielectric Strength 22,600 Volts Propellant Carbon Dioxide NSF Registered No Aerosol Flammability Level III 360 Valve Yes DOT Proper Shipping Name Consumer Commodity, ORM-D VOC % (Federal) 95 VOC g/L (Federal) 636.4 VOC Lbs./Gal. (Federal) 5.3 VOC Compliant For CA Not Regulated VOC Compliant For OTC/LADCO Not Regulated
    Oi mayrun na pala niyan. My thinking is anything that dries up quickly would do kaya hindi pede yun WD40 dito. Naka indicate din naman sa mga popular carb cleaners "MAF safe"
    Oct 2008
    bugahan lang po ng hangin pwede na po yun tnx
    Nov 2003
    a spritz with carb cleaner should do the trick.
MAF cleaning (a32)
