Results 1 to 18 of 18
    May 2005
    I was wondering what is the proper way to check the engine oil level, dapat ba pag umaga i check, yung tipong di mo pa stinastart? o istart muna and then ioff tapos saka check. Conflicting opinions kasi nakukuha ko, sabi nung tito ko dapat pag nagchechek yung di pa daw nastastart, sa gas station naman ang sabi sa akin kelangan umandar na daw para naka circulate na daw yung langis. Second hand kasi namin nabili yung auto ko kaya wala ng manual eh.
    Dec 2003
    i usually check on it sa umaga, nakapatay pa ang makina.. bago ko istart... check on the color of the oil and if hanggang saan nalang siya.. kung nababawasan ba mabilis.. or may leak na..
    Check oil before starting the engine.
    check oil when engine is cold (hindi pa nastart)
    pero pag mga euro cars (ang alam ko sa MB), kelangan mainit makina bago check ng oil level
    Aug 2004
    For air cooled porsches, 30 mins running engine before you check the oil.
    I check it both hot and cold.
    Quote Originally Posted by OTEP
    Pareho tayo... para sure. :D
    Aug 2004
    to get the correct reading, the vehicle should be on a level spot. with the engine at operating temperature and turned OFF, wait say 5-10 minutes to let the oil drain back into the bottom and then check the oil level on the dipstick...
    pull it out, wipe it clean, reinsert as far as it will go, then pull it out again and look at the fluid level on the end..
    hehe... parang iba na yata meaning nun ah..
    Quote Originally Posted by raikonen
    yup... wait 5-10 minutes...
    maraming nagogoyo sa mga gasoline station sa ganyan. nung papunta akong batanggas, sinubukan ko lang ipa-check just for the fun of it (at di ko naman gawain ang ganun).
    ayun, according to the dipstick... 1/4 ang kulang ko... sabi nung gasoline boy dagdagan na raw. sabi ko naman eh kaka change oil ko pa lang sa casa. sabi nya, ganun daw talaga kapag kakachange oil pa lang... nababawasan (huh?).
    pagdating namin ng batanggas, after resting the vehicle for a while, chineck ko. back to normal ulit.
    May 2005
    salamat thanks for the info!
    May 2007
    nalilito ako dun sa pickup ko(nissan eagle), pag kakaandar lang ng makina then after mga 5-10 mins nakapatay, yung oil level nya sa dipstick is mga 1/2 lang.
    pag overnight naman nakapatay then check sa umaga e lagpas sa full.
    nag overfill kaya ako?
    Quote Originally Posted by lnce420 View Post
    oil travels inside the engine when in use, so it does not stay in the oil pan/catch(forget the exact term) underneath the engine. and of course, if engine is off, the oil drains back to the oil pan, that is where the dipstick reads the level of the oil.
    if lumagpas sa full level ang reading, maybe you have overfill it. its not that harmfull but on your next change oil, better be sure to fill it just right.
    lutang pa ko
    Quote Originally Posted by aejhayl17 View Post
    That's right! Kaya mas magandang mag check ng oil level pag umaga, before starting your engine.
    IMHO, overfilling your engine with oil may not cause harm to it but will affect its performance . . . Sa experience kasi namin ay medyo hirap humatak pag "lunod" yung makina sa langis.
    Last edited by jjmd3_787; February 28th, 2010 at 04:27 PM. Reason: tao lang po . . .
    Mar 2004
    Mga sirs, try running on a knee deep water. tignan kung gaano kahirap. this is comparable to an engine overfilled with lube oil.
    Mar 2004
    Ooooppppss. sori. double post
    Mar 2004
    Quote Originally Posted by jjmd3_787 View Post
    imho, mas ok saken yung warm up the engine muna then let the oil drain back. then check the oil level
checking engine oil using dip stick
