Results 1 to 10 of 18
May 29th, 2005 07:30 AM #1
I was wondering what is the proper way to check the engine oil level, dapat ba pag umaga i check, yung tipong di mo pa stinastart? o istart muna and then ioff tapos saka check. Conflicting opinions kasi nakukuha ko, sabi nung tito ko dapat pag nagchechek yung di pa daw nastastart, sa gas station naman ang sabi sa akin kelangan umandar na daw para naka circulate na daw yung langis. Second hand kasi namin nabili yung auto ko kaya wala ng manual eh.
May 29th, 2005 08:06 AM #2
i usually check on it sa umaga, nakapatay pa ang makina.. bago ko istart... check on the color of the oil and if hanggang saan nalang siya.. kung nababawasan ba mabilis.. or may leak na..
May 29th, 2005 11:31 PM #4
check oil when engine is cold (hindi pa nastart)
pero pag mga euro cars (ang alam ko sa MB), kelangan mainit makina bago check ng oil level
May 29th, 2005 11:39 PM #5
For air cooled porsches, 30 mins running engine before you check the oil.
May 30th, 2005 12:06 AM #6
I check it both hot and cold.
May 30th, 2005 02:32 AM #7
to get the correct reading, the vehicle should be on a level spot. with the engine at operating temperature and turned OFF, wait say 5-10 minutes to let the oil drain back into the bottom and then check the oil level on the dipstick...
pull it out, wipe it clean, reinsert as far as it will go, then pull it out again and look at the fluid level on the end..
hehe... parang iba na yata meaning nun ah..
May 30th, 2005 09:31 AM #9
Originally Posted by raikonen
yup... wait 5-10 minutes...
maraming nagogoyo sa mga gasoline station sa ganyan. nung papunta akong batanggas, sinubukan ko lang ipa-check just for the fun of it (at di ko naman gawain ang ganun).
ayun, according to the dipstick... 1/4 ang kulang ko... sabi nung gasoline boy dagdagan na raw. sabi ko naman eh kaka change oil ko pa lang sa casa. sabi nya, ganun daw talaga kapag kakachange oil pa lang... nababawasan (huh?).
pagdating namin ng batanggas, after resting the vehicle for a while, chineck ko. back to normal ulit.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
