Same same. Valve lift will not change static compression but it could alter dynamic compression depending on the overlap and how fast the intake charge enters.
I don't understand how you're going to implement that. The amount of valve lift is dependent on the cam profile. Unless the cam is severly undercut, then longer valve stems means that your valves will not close completely. But if this modification takes the cam profile into account and the valves do close completely when they ought to, the higher lift should give you more power.
Whether it lowers compression will depend on how large the overlap is between intake opening and exhaust closing. If and only if there is considerable overlap, more lift will lower effective compression.
You'll notice a loss of low end torque, cold starting will get worse, and the engine might run hotter in traffic due to improper combustion. But that's only if the extra lift is too aggressive.
And, of course, if the extra lift is too aggressive, you run the risk of bending a valve against the piston at high engine speeds. Better valve springs will be a must.
But higher lift means more air, which means more power at high rpms... if and only if the valves themselves don't flow enough air to match the intake and exhaust ports ability to move it or the cylinder's ability to suck it up. And if the ports themselves are not undersized and providing a restriction. It's sure you'd see some gains, but I can't say how much.
But I really don't understand how you are going to run longer valves without changing cams. Seems the wrong way around. Those of us who fiddle with this stuff change the cams, as this is a surer way of getting a performance boost.
What engine is this, and who's selling the valves? What brand of valves are these and what is the performance claim?
