Results 1 to 18 of 18
    Oct 2015
    Hi ask ko lang yung rav 4 2007 (80k+ km on odo)namen mababa yung idle rpm(500 rpm) to the point na nag shake na yung car.
    It only happens when gear is on "d" approaching a stop light and slowly stopping. Once on full stop rpm goes down to 500 and stats to shake.
    Nawawala sya pag ginawa ang isa sa mga eto.
    1. Light turns green then release brakes and step on gas pedal.
    2. Shift the gear to neutral. (Rpm kicks to 800)
    3. Turn off the whole aircon system. Or turn ac to blower only.
    Napagawa ko na sa car.
    1. Change oil and filter. (Royal purple 15w-30 malapot ba sobra eto?)
    2. Change atf ( drain and replace. Not dialysis)
    3. Changed engine air filter
    4. Cleaned throttle body.
    Meron ba engine tuning for rav4?
    15w30? I dont remember this from royal purple...
    Oct 2015
    Double check ko yung royalpurple na oil weight. Yan kase push ni ate sa akin maganda daw para sa toyota vvti.
    Pero gusto ko sana ilagay yung mas malabnaw.
    have your throttle body cleaned. ganyan naging sakit ng sentra ko before eh.
    Oct 2015
    Throttle body was cleaned last week. The problem still insist.
    Meron bang engine tuneup for vvti engine?
    Jun 2005
    ^ how did you clean it? Spray lang or disassemble nung TB? Have you cleaned the maf sensor as well?
    Feb 2009
    If you have access to a scan tool, check airflow into the engine at idle would be around 1.8 grams of air per second. Check and service the idle air control.
    Oct 2015
    Sa wilson and jackson ko pinagawa. Cervo overhaul ang tawag nila sa paglinis ng throttle body. Pero di pwede tignan habang ginagawa yung car. So di ko alam kung paano nila nilinis at kung kasama yung maf sensor sa paglinis.
    Oct 2015
    Saan pong talyer ang may scan tool?
    Feb 2009
    Saan ba ang cervix😀
    Oct 2015
    Cervix? Sa babae lang yun diba? Haha.
    Oct 2009
    check spark plugs.& HT wire
    Feb 2009
    bagong part yun- servix
    Jul 2006
    Wilson and Jackson is an auto shop pala?
    Sorry, I had no idea ...
    Oct 2015
    Wilson and jackson medyo sikat sa north manila.
    Papacheck ko next yung ht wwire and spark plug.
    Apr 2008
    Try the IAC valve. It was the culprit when our Tribute had rpm fluctuations.
    Sent from my SM-G900I using Tapatalk
    Oct 2015
    Mag ka iba ba yung throttle body and iac?
    Hindi ba sila isang assembly?
    Apr 2008
    IAC is idle air control. With my car it was definitely separate from the throttle body. It's just a tiny little thing.
Low rpm on idle on Rav 4 2007 2.4l
