Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    May 2008
    mga bro 2long naman, anu ba mabibigay nio sakin tip o mga dapat ipaadjust sa makina para makatipid sa gas,, mejo nalalakasan kc ako sa gas e 7 to 8 km/L matic oto ko nissan sentra gts..tnx
    Aug 2005
    Quote Originally Posted by nissan gts View Post
    IMHO, the driver has to adjust his/her driving habits.
    Aug 2007
    +1 on this.. i hope nasagot na yung tanong mo
    May 2008
    dapat ba tsinetsek din ang timing?posible bang nababago timing katagalan?
    May 2007
    of course timing is a must. Iwasan ang katatapak ng preno, anticipate your distance hindi tutok para maiwasan ng preno. Remember, accelaration gulp too much gas.
    Jul 2006
    Have it adjusted to its factory specs, tune it up to its optimal performance, and then from there adjust your driving habits. Remember, braking is wasted energy (in the form of heat) so use momentum as long as you can. Accelerate slower, and avoid decelerating. If you must, do so well before your estimated stopping point to minimize loss of momentum. Adjust tire pressures too, that helps attain good fuel economy, and finally remove any junk in your car that you don't need.
    You can't do much really, since your car is an automatic. A/T equipped cars tend to consume more fuel than M/T equipped cars of the exact same specifications. If you don't know when it's last been done, have the ATF replaced too - drain and refill lang yan wag mo na ipa-flush.
    May 2008
    tnx mga bro!!! ok tlg d2 sa tsikot dami ko natututunan...
    Apr 2004
    may i also suggest you have the throttle body cleaned, all oxygen sensors, valves adjusted and timing set for the particular type of fuel you like to use.
    tyre pressures to 31psi. oil change to thinner, more fuel efficient grades (like 10w-30 or 40).
    I think Timing adjustment ... Go to Speedy fix, for a 200 Pesos labor charge.. Sweet . pwede diba....
    Aug 2005
    Can we list kung alin sa mga tips na ito ang may pinaka malaking contribution to fuel economy. IMHO, number 1 is driver.
    1. Driver
    2.
    3.
    4.
    5.
    Oct 2007
    1. Driver
    2.
    3.
    4.
    5.
    2. PMS on time
    Nov 2003
    tire pressure
    oil viscosity
    route
    Quote Originally Posted by speedyfix View Post
    tire pressure
    oil viscosity
    route
    ano po effect ng oil viscosity sa fc?
    Put a brick under the gas pedal hehehe. . . Kidding aside oil viscosity really helps kasi thinner oils tend to free the engine components and thus contributing to fuel economy. Pero If I Were you i'd stick to factory specs na lang, and ease of the gas pedal.
    - keep your car in top condition.
    - i also read na don't go beyond 80kph daw.
    - make your car lighter, basic tools at spare tire lang ang dapat na laman ng compartment.
    - +1 sa oem timing settings.
    - correct tire pressure.
    others:
    kapag malapit lang pupuntahan, commute na lang.
    OT:
    malapit na naman ang weekend, tataas na naman ng piso. :-(
    Jul 2006
    Quote Originally Posted by spyghost View Post
    Less viscous or thinner oils allow the parts to have less friction between them, requiring less energy, and therefore less fuel to be consumed. It also provides easier starts, which again means less fuel consumed to start the engine compared to a thicker oil.
    Jun 2006
    buti ka nga 7 - 8 km/l matic mo, sa akin nga eh 5 - 6 km/l...
    you can try doing hyper-mileing techniques when possible to stretch to the maximum each liter of fuel you have.
    -smooth and easy acceleration
    -moderate maximum speed
    -use coasting as much as possible
    -use the brakes as little as possible
    -use the car's natural deceleration as you slow to a stop at intersections
    What's coasting?
    What's coasting?
    Driving at a certain speed with your manual tranny in neutral. The car would simply move using the momentum you have built up.
anu ba ang mga dapat e adjust sa makina para mkatipid sa gas
