Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Apr 2008
    anu po ba ang pinaka ok na synthetic & un price po nya???anu dn po pinaka mura na synthetic oil? due na po kc ako for change oil...last time na nagpa change oil ako sa rapide it cost me 4.2k for go synthetic service nila...tpos d naman napalitan fuel filter ko...another question is kaya po ba do it yourself pag palit fuel filter???panu po ba???my car is crv 1st gen 98 model...tnx po...
    punta ka na lang sa shell (helix ultra), petron (ultron race) or caltex (havoline) gas stations, they have fully synthetic in their product line para makapili. stay away from rapide as much as possible. sa daming negative experiences na posted sa tsikot. search mo na lang.
    madali lang magpalit ng oil filter but you need filter wrench kung sakaling sobrang sikip ng dating nagkabit. ideally every 4-5,000 kms ang palitan nito. mas earlier the better.
    Aug 2007
    try nyo po yung synthetic oil ng shell, around 2K plus.. ang gamit ko kasi mineral oil lang and every 5000km ako nagpapa change oil sa shell, and kalimitan naman pinapalitan nila sa kin is oil filter lang.. or try nyo din pala sa speedyfix along shaw, they use royal purple synthentic oil. regarding naman sa fuel filter, pwede din naman kayo na ang magkabit kaya lang in my case pag bumili ako sa kanila ng fuel filter libre na ang kabit..
    use the search function...sobrang dami ng topic about fully synthetic oils....try royal purple, meron pa yatang promo si speedyfix...
    Gamit ko Redline 1 un sa pinakamagandang synthetic 2,650/gal po sya sa superior motors. Polyol Ester po base nya kaya mahal d tulad ng ibang synthetic na synthetic base stock lang. 10 yrs ko na po gamit sa 2 sasakyan ko na parehong d pa naooverhaul. 140k klms na mileage bawat sasakyan.
    Apr 2008
    i just wanna ask kun san ka po bumibili fuel filter???para dun na dn ako bbili at papakabit ko na dn...many tnx... ill check out speedyfixtga mandaluyong dn me kaya malapit lang d2...
    Sep 2004
    Quote Originally Posted by JoyOfYep View Post
    mag speedyfix ka na lang po. lapit lang sa inyo and i think meron sila mga promo change oil..sa fuel filter naman, depends sa brand ng car ninyo, any auto shop should have the equivalent, just make sure you have the parts number or tell them the exact model of your car. i bet sa speedyfix they have that as well.
    imho and afaik, the shell synthetic package change oil is around 3k pesos. includes 4 liters of full synthetic, oil filter and labor.
    what i would suggest is you get your oil outside (shell fully synth is excellent). and just go to a shell station and get the filter and labor from them. can save you at least around 15% of the cost.
    laki kasi ng patong nila sa oils eh. mas mura sa Ace Hardware (where i get my Shell Semi-Synth oil too.)
    kasi, hindi naman sila nag change oil if your oil is not shell.
    pero yes, punta ka na lang kay speedyfix. i think he uses Royal Purple and Motul.
    Apr 2008
    onga eh malamang po sa speedyfix na nga lang kc 2.1k package nila...
    Apr 2004
    honda vtec-lev fully synthetic pa rin the best i've tried so far. and i've tried plenty (including all variants of the mobil fully syn brand). if you go for synthetic and plan to leave it in the engine for 1 whole year, best to get the orig honda oil filter. it's bigger and heavier than Vic filters, so it could have more filtration mass sa loob. mas maganda.
    if you'll just change oil out after 5 -6 months or so, go regular mineral na lang. panalo pa din yung 10w-40 ng honda casa. 850 all in pati labor and oil filter. orig pa.
    NEVER EVER use cheap 20w-50 oil. masyado malapot. lalakas pa sa gas ang crv mo. but don't use the super thin oils either (mobil 0w-40). my old crv developed scuffed camlobes after using this oil and havoline energy 5w-40.
    Dec 2007
    Kakatapos lang ng warranty period ng kotse ko. Had my last oil change in January I think, so I have Honda's fully-synthetic oil in my sump (which is actually provided by Idemitsu).
    Now I'm rather curious, opting between Motul (at Autoplus) or Royal Purple (at Speedyfix). Matagal-tagal pa naman ako bago ko kailangang magpalit ng langis ulit.
    Apr 2004
    these days any synthetic will do nicely anyway...
    in fact, most mineral oils are patok na din for value. kahit yung sa petron with the lousy packaging. wag lang yung 20w-50s.
    if i had a lot of money i'd stick with honda branded oil. there's some sort of implied warranty for the engine internals if you take it to them for servicing on a regular basis since 50% of broken internals result from bad oil pagdating sa honda. oil lang nila gamit mo eh, so if you suddenly break a camshaft, wala naman sila sisisihin eh, hehehe. and if you're friendly and remember to tip the SA from time to time, you can have things checked out for free.
    Mar 2007
    Good Day...
    You mentioned - you want to do it yourself... and also, gusto niyo makatipid.
    My question... bakit kailangan synthetic?
    If you want makatipid.. then you can change your oil yourself. This is probably one of the easiest job for any DIYer's.
    Any 10W40 Oil will do... But in my experience...(that includes racing and daily driving), Ultron is one of the best cheap oils you can buy.
    Buy a filter... and buy also a filter spanner tool... marami diyan sa auto-supply or ACE or Handyman.
    Be sure to warm your engine up at least 5 minutes... turn it off. See your owners manual to locate the Drain Plug... then alow oil to drain but see to it you have an old plastic or Can big enough to hold all your used oil.
    removing the oil Cap is also advised when you do this... para mabilis bumaba yung langis.
    Then as is cools down... you may remove the oil filter. To remove it... use the Oil Filter removal tool... since this is somewhat not easy to turn with your bare hands. As soon as this is done. You can ready your new Oil Filter by applying a small amount of oil on the seals.. (o-ring, subber seal) facing the metal surface of the engine block. Be sure to wipe the mating area with a clean clothe para walang dumi. Then Hand tight the oil filter in place (clockwhise rotation)... see to it that aligned ang filter dun sa thread ng inlet stud ng engine block para hindi masira yung filter. (just do it with care) dont over tight it para hindi masira ang seal.
    WHen this is done... and wala ng tumutulo na oil... then you can put back the drain plug in place... and pour in your new Oil.
    Replace the Gas Cap... then start your engine.
    Para - mas sigurado... I would suggest using NewOil additive (P500 per treatment). This is an additive that treats the metal and conditions your oil ... it elliminates oil acidity and keeps your engine frictionless too. )(based on my experience... what I suggested made my engines more efficient and I get to enjoy them for less than the average cost you are doing with your car.) And when you do this... you dont have to change oil for the next 2 years. You may if you want but it will only be unnecessary. (This is where real savings comes in) (not to mention your engine's protection - wear and tear is prolonged and will mean savings again from periodic maintenance).
    With the above tip... you will be able to lower your Oil-Change cost to roughly P1,500 more or less (All in)
    Allow extra P100. for your merienda, for sure, medyo pagpapawisan ka when you do this.
    I hope this helps.
    Nov 2003
    any viscosity of the RP full syn line (not XPR) is 440/liter except the 5w40 which is 550/liter.
    Apr 2008
    how much po ba ang ultron rallye ngayon???
    Apr 2004
    last oil change 2 months ago... 1,200 per gallon
    Quote Originally Posted by ehnriko View Post
    Good Day...
    I hope this helps.
    ok na sana eh, kaso nasingitan pa ng additives, IMO no need for additional additives....
    so the oil doesn't keep the internal parts of the engine frictionless? I always thought that the oil does that, hinde pala...and hinde magpapalit ng oil for 2 years!? sobrang galing naman ng additives mo...hehehe
    Medyo meron pang subliminal advertising na nangyari :hysterical:
    IMO additives are a waste of money . . . .
    Jun 2006
    Most car manufacturers do not recommend using oil additives. I belive they even put it in writing in the manual or warranty booklet.
    Apr 2008
    I think the best oil for your car, is the one that your budget can afford... .... additives are all hype.... engine oil is formulated with ALL the necessary additives for your vehicle's engine... so one should never experiment adding this or that without proven and verified results....
    just my 0.02
anu po bang oil gamit nyo synthetic?anu price?
