Results 1 to 10 of 15
    Jan 2009
    Quote Originally Posted by benoy View Post
    Follow up question lang po:
    Kung sa daan inabot ng sira ang ETCS, posible pa po ba na mapatakbo ang auto hangang sa casa or repair shop? Unlike kung cable, pag naputol pwede idugtong or taasan ang menor. TIA.
    If it's stuck at idle or high-idle, you can limp your way home. Otherwise, your only choice is to have it towed.
    But you'll be glad to know that this almost never happens. At least, I've yet to hear of such occurrence happening to anyone.
    Nov 2003
    it won't happen too often but you did have those occurences in the US with toyota... or at least that's what the goverment is saying with the unintended acceleration and all. di naman daw affected local units but you never know...
    thanks for the reply!
    Aug 2004
    An electronic throttle failure is unlikely. It's much more likely for your ignition coils or your cam-position / crank-angle sensors to give out and leave you completely stranded than it is for the ECT to fail...
    Unintended Acceleration is pretty bogus. Even on an automatic car, you can slot into neutral with the engine racing. And even in the event of throttle failure, all ECT cars nowadays are programmed to disconnect the engine from the transmission when you step on the brakes.
    Never experienced unintended acceleration with a cable-throttle car? Really? It's called getting the cable stuck. And that happens much much more often than ECT UIA.
    Apr 2011
    Wow, nice to see this thread come to life again. Now that we got the ball rolling, i'd like to know anyone from Tsikot who have experienced a throttle failure in their DBW car (throttle motor failing, pedal sensor failure, etc and how much it cost to replace)
    *SpeedyFix, can you provide any details on this one?
    Nov 2003
    i see the failure most on xtrail dbw throttle bodies. not too much in toyotas except during ondoy.
    on xtrails it's sometimes possible to reprogram the idle with the help of CONSULT software but not all the time lalo na if you move the throttle plate by hand.
    Jun 2011
    Ah I've heard of some problems about this DBW throttle bodies also. My Aunt had a problem on DBW on their Benz C class, and AFAIK, one of Toyota's recall last year was due to a sensor of their DBW failing causing the butterfly to stick open.
Longevity and Reliability of Drive By Wire Throttles
