Results 11 to 20 of 21
October 2nd, 2012 11:49 PM #11
Ah. I've done that too. Painful. Cracked the cylinder head on my Sentra in a flood. We had an odd burp in the coolant temps after the overhaul that we couldn't trace... and that was the finding.
- Aug 2012
- 12
October 9th, 2012 12:52 AM #12
- Jun 2005
- 3,774
October 9th, 2012 01:25 AM #13
October 9th, 2012 09:25 AM #14
- Aug 2012
- 12
October 9th, 2012 01:54 PM #15Thanks for the input. So basically, konti lang ang difference ng gastos pag general overhaul and pag bumili ng surplus? Parang mas may advantage ang pag bili na lang ng surplus cause I do have plans of getting a stronger engine para mas gumanda ng konti ang takbo since I own a matic car.
- Aug 2012
- 12
October 9th, 2012 01:57 PM #16I don't know kung what type ng compression check ang ginawa eh. Di din nilagyan ng oil yung cylinders. Yun lang yung reading na binigay sakin. Loss compression lang engine ko e, di naman nagbabawas ng langis masyado. Do you have figures sir ng rough estimate ng general overhaul?
- Jun 2005
- 3,774
October 9th, 2012 09:38 PM #17
October 9th, 2012 09:56 PM #18
Should get a leakdown to determine why the compression in those two cylinders is low. It can basically pinpoint where the pressure is going, whether out the piston rings or through the head gasket.
- Aug 2012
- 12
October 14th, 2012 12:26 AM #19
- Jul 2010
- 570
October 14th, 2012 03:44 PM #20Dati low compression 4G13 engine ko at pinalitan ko ng 4G15 engine. Almost same lang result ng FC 6km/ltr. Hindi ko kasi pina overhaul yun nabili ko surplus na engine 4G15.
So, I end up na ako na mismo nag DIY rebulid ng 4G13 engine ko para sure ang pagkagawa at mas tipid pa. 12K gastos ko kasama na yun machine shop rebore at relining and parts at mounting ng 4G13 uli sa kotse ko. Almost 160 PSI result dry compression test ko sa mga cylinders ko. Hindi na masama sa first time engine rebuild ko.
Nakatabi na lang 4G15 engine ko ngayun at general cleaning ko uli lahat ng parts para benta ng chop chop.
If I were you. General overhaul mo na lang dating engine mo. Kasi yun surplus engine ay pa-overhaul mo para tipid ka sa gas and for better performance. Pwera pa dito yun sakit ng ulo at gastos ng pag change engine LTO.
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
