Results 1 to 10 of 14
- Dec 2004
- 89
October 31st, 2005 03:09 PM #1pano po nangyari yun? kasi kahapon pinasok ko sa garage yung mazda 323 namin. napansin ko parang may umuusok. then kanina ilalabas ko sana pero pag check up ko, wala pala yung cap ng oil! ano kaya nangyari? TIA
October 31st, 2005 04:02 PM #2
maybe the oil cap was loose and then engine vibration rotated it out until it fell?
- Dec 2004
- 89
October 31st, 2005 05:22 PM #3enough ba yung vibration para matanaggal yung cap? di naman nagalaw yun recently e..
follow up question: may bad effect po bang umandar ng nakabukas yung cap?
- 3,754
October 31st, 2005 10:37 PM #4Baka hindi maayos pag kaka kabit ng CAP.. then in the long run due to vibration nasira ang thread... plastic lang yon diba?? heat and vibration can damage it.. palitan mo nalang observe mo rin engine temp. mo baka hindi na normal..
meron effect yan pag umandar na bukas.. mag babawas ng oil... and worse eposed ang engine mo baka kung anong pumasok dyan that can damage..kahit buhangin lang sisirain ang makina mo.
- Mar 2004
- 74
November 1st, 2005 02:10 AM #5pag may leak ba ng oil from the oil cap or valve cover gasket e, magrrise engine temp? or abnormality sa daloy ng tubig sa radiator?
Tsikot Member Rank 3
- Jul 2004
- 1,526
November 1st, 2005 05:44 PM #6nangyari na to sakin before... parang mausok and mabaho.. tapos pag bukas ko ng hood! what the?! kalat kalat ang oil sa engine compartment. luckily the oil cap was still in the engine bay area.. pero natanggal sa lalagyan niya.. ayun, dinagdagan ko na lang ng oil un engine and binalik oil cap tapos wala naman masamang nangyari.
November 1st, 2005 07:13 PM #7
bro ganyan din nanyari sa lancer box type ko dati, pagbukas ko wala na oil cap, yung oil cap yung pinaka lock niya sa ilalim nakasecure ng screw sa vibration nagloose ang screw at natangal, nahulog sa loob yung screw at pinaka lock niya, pero hindi ko alam noon na naandoon pala kaya noong nagpaadjust ako ng valve clearance doon lang nakita na nahulog sa loob.
- Dec 2004
- 89
November 2nd, 2005 08:52 AM #8pareho nga kami ni glntVR. ganun din except di na nakita yung cap. pinacheck namin, piston ring daw yung problema. pero di ko pa alam yung details..
November 2nd, 2005 02:46 PM #10
Originally Posted by konde
honda could bring their mobilio/brv diesel too from india as a response though that is if they...
(Maruti) Suzuki's 1.5L Diesel Engine
