ask ko lang bakit ung advie nmin ay kumakalog kapag ino-off ung engine long run or short run, basta pag papatayin kumakalog sya. sbi ng iba ay kaya ganon gawa ng nk advnaced daaw ung timing ng engine. tnx sa mga magrereply.![]()
it is an effect of an "overly advanced" timing. if you're timing is stock (as per manufacturer specifications), it could be a faulty ignition or dirty combustion chamber (carbon deposits). as for the carbon deposits, it may sound a bit silly, but hataw driving could do the trick. change oil frequently, as well as other things plugs, filters.
Normal yung kumalog ang diesel engine sa very low idle, lalo na sa pag shut-down. Mataas kasi ang compression pressures ng mga diesel engines.
Meron additional device ang new diesel models para mabawasan ang pag kalog.
So don't worry.
Do you mean just a little "shimmy & squeak"? That's normal on almost all diesels. The thing is, the combustion events in a diesel are so abrupt, ganoon din sa mga gas engine, that when you shut it down, the engine stops like RIGHT NOW, and the accessory belt keeps going momentarily, causing the squeak. The abrupt shut-down also causes a little shake when you shut the engine off. It's more pronounced in the Cummins than the PStroke or Dmax, but they all do it to some extent.
How old is your advie? Baka worn out na ang engine support.
:coffee: [SIZE="1"]4123[/SIZE]
thanks dieseldude, I think this week pupunta father ko sa central diesel.
