Originally Posted by
gooseflights
Mga gurus, ano po madalas na engine break-in procedure na ginagawa niyo sa newly rebuild engine (Palit bearings, pistong ring & main bearing) ? i read lots of info about engine break-in pero nalilito ako dahil medyo marami at iba-iba ang procedure na ginagawa nila.
so far ito yun common thing na ginagawa nila:
- Use ordinary engine oil during the break in
- tune-up before break in
- Break in for at least 500miles (800km ?).
- RPM should not exceed about 3500.
- Try not to use aircon during break in.
- Keep under 55mph (88kph tama ba ito?) for the first 500miles
- Don't accelerate overyly hard
- Drive on slow-speed trips as well as moderate-speed trips
After first 500miles, Chang-oil, oil filter, tune-up and adjust valve clearance. Then follow the PMS.
Is thing procedure good enough to break in my newly rebuild engine? TNX
