Results 1 to 9 of 9
    Sep 2008
    Good day!
    Currently owning ae92 po o ang tinatawag nilang corolla small body, since medyo matanda na ang ride na ito at nakaipon narin ng konting pondo, pinagiisipan ko talaga kung engine swap to 5a or overhaul nalang yung stock na 4a. Nakapagcanvass narin ako, pag engine swap papalo ng 40-50k ang damage tapos pag overhaul 30+. Ano po kayang pro's and con's ng dalawang option. Si tito ayaw magpacomputer box lalo na daw kung surplus din ang ipapakabit kase medyo mahal daw ang pagagawa kung masira man. Kelangan ko lang po ng konting enlightenment.
    TIA! God bless
    Quote Originally Posted by eto_ako View Post
    Good day!
    TIA! God bless
    imho... engine swap, kailagan mo ba ng more powerful?
    overhaul.... kailangan mo na ba talaga mag pa overhaul? may loss of power na?
    kung wala pa naman.... tago mo muna pera mo for future repair.
    Jan 2011
    consider your need. is it power or economy? from then on, decide.
    If i were you, since you are willing to spend 40k-50k, i would spend it on a tune up or overhaul, and fix small problems such as rattling sounds, broken power windows, suspension bushings, skipping wiper blades, dirty headlights, etc.
    There is nothin more satisfying than driving a car without any problems and rattling sounds.
    Quote Originally Posted by nivraarvin View Post
    +1 ako kay Sir!
    is the car showing signs that it is in need of overhaul? remember that this is an old car, and it would not be fair of you to demand that it function as responsively as the more modern cars 20 years younger.. it can't do that even if it were fresh off the factory.. perhaps it is not in need of overhaul at all..
    yes, maybe a tune up muna.. maybe some fixin' up of the passenger comforts..
    btw, the ability to stop is even more important than the ability to go..
    be sensible.
    Apr 2010
    Tune-up nyo muna sir para good condition. Repair-repair muna, lalo na body parts both exterior and interior. Then use it until the last breath ng makina, sulitin nyo. Then change engine na.
    HTH
    Jul 2006
    Sell your current car, add the 40-50K, and buy a newer 2nd hand Corolla or any other car of your choice.
    i suggest spend on repairs or overhaul if needed. mas may assurance ka sa newly overhauled engine (provided it is done right) kesa sa surplus engine that you are unsure when it'll conk-out on you... and if that happens, you're back in square one imho.
In need of experts advice :)
