Results 1 to 5 of 5
- Jul 2007
- 10
February 7th, 2008 12:35 AM #1Need help! My old 93 Corolla Gli has problems with its RPM. Minsan it goes 1500 rpm on Normal Operating Temp then goes back to 1000. Then minsan bumababa ng 800 rpm at may "palag". Panu ko susulusyunan ito? Anu papa-ayos ko?
February 7th, 2008 04:34 PM #3
Sabi sa akin before...baka daw:
1. Air sensors
2. Reset the computer
3. Filters need replacement
try mo na lang.
February 7th, 2008 05:15 PM #4
sir, if your engine is EFI, theres a chance that your IACV "Idle Air Control Valve" or the TPS "Throttle Position Sensor" is worn out or clogged (the IACV) or needs to be adjusted (the TPS). also check for Vacuum leaks as well.
aite, peace.
- Jul 2007
- 10
February 12th, 2008 01:11 AM #5Thanks Guys! This is such a big help! Hope to get it fixed soon. God Bless!!!
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
