Results 1 to 20 of 20
    Feb 2007
    question:
    bat pag naka idle yung oto ko biglang bumababa yung RPM bago naman spark plugs ko, high tension wires. tsaka totoo ba na yung carburaetor magnetic jet dapat nag sspark sya whenever it makes contact with something inside the carb? yung sa oto ko kasi hindi eh, would that be one cause of that?
    Feb 2007
    car ko nga pala 1993 honda civic LX (carb)
    ganyan din sa akin... 94 eg hatch ph12 carb type.... nagsawa na ko pagagawa sa mga mekaniko d2 pque bayad ka ng bayad la naman nagagawa...kapa system din naman sila madalas eh.... DIY ko na lang.. ,,, experiment ng mga iba ibang adjustment screws sa carb from air, to idling, to fast idle.masyado pa complicated ung cleaning ..research muna.. pati nga timing pinakialaman ko na din.. tutal ung last mechanic ginalaw na din without using a timing gun.....gusto ko nga try ipa overhaul carb kay speedy,,,la pa lang talaga ko breads ngaun...DIY muna...pag nasira makina may rason na ko mag engine swap hehe
    Feb 2007
    try ko kaya palitan yung buong carb kasi malamang may somewhere dun sa carb eh. may tinakpan na dati dun yung mechanic pero bumalik nanaman yung sira. alam ko puwede i convert yung carb to EFI eh. para d na mag engine swap. try mo pihitin yung pin na nasa likod ng carb mo, see if that will make any difference. Hindi ba pumuputok yung muffler mo when u let go of the gas while the car is moving?
    Jun 2006
    Baka yung Aircon compressor mo nag-eengage. Not sure but i think it's normal. Ganyan na ba talaga sya ever since?
    Feb 2007
    ok naman a/c ko dude eh, the thing is, the problem happens when i turn the a/c off. I've had some issues with the idle up mechanism, nawalan lang nang contact, ni reseat lang ng mechanic and has been resolved. Im left with the idea of doing a top-ovehaul since Ive had overheating problems in the past. My ph12 engine has never been overhauled.
    Feb 2007
    tsaka pala after a long trip, pag pinapatay ko yung engine parang may nadidinig akong sumusuka sa hood, im talking about the engine. not my drunk passenger. Ü the sound is like, kwuuuuuuuuk!!!! sometimes it's like, kwaaaaaakkkk!!... (i tried my best) LOL.
    Jun 2006
    That is sooo weird. LOL.
    yung ticking sound kasi after turning-off the engine is normal pero yung ganyan, ngayon lang ako nakarinig nyan. hehehe
    Feb 2007
    carb kasi oto ko dude eh! maybe u deal more on EFI's. Im gathering some dough to do an engine swap the b16a eg is so expensive, the one that I know of was like 60k!
    Sep 2005
    kung carb overhaul, sa m3m kamuning ka magpagawa 600 lang yung sakin. same tayo ng engine.
    may alam ba kayo na matino na nag ooverhaul ng carb dito paraque?..
    Feb 2007
    mukhang hindi aabot sa kanto pag dinrive ko oto ko eh! sa kamuning pa kaya! i need a bnew carb! para walang prob. magkano kaya
    Feb 2007
    sa pque wala dyan, puro efi specialist nandyan eh, laspinas nga wala rin. konti nalang mga magaling gumawa ng carb ngayon eh.
    Feb 2007
    may alam ba kayong nag cconvert ng carb to EFI?. Alam ko meron nun eh
    Nov 2006
    Kung carb type ang mga oto nyo, malamang yung butterfly sa carb ang may problem dyan. medyo hindi na fit sa butas maaaring lumiit na ang butterfly or hindi na siya bilog.
    Kaya pang i-repair yan dalhin mo lang sa magaling mag-overhaul ng carb na malapit sa inyo.
    Nangyari na sa akin yan kaya alam ko.
    Sep 2004
    guys makisingit na rin effective ba ang mga carb cleaners na nabibili sa handyman, ace , etc.? kc gusto ko bumalik yung auto choke ng carb ko parang takot naman ako magpa overhaul ng carb baka di maayos pagkagawa. btw lancer 95 EL ang car ko piston type carb
    TIA
    Feb 2007
    yes you can get a carb cleaner but that would not really be fit if you are still having problems after cleaning it and all that. I had replaced my carb's butterfly and pretty much had it opened and examined but the mechanics actually lack the ump in determining what the real problem is... I might as well pick up a new carb from elsewhere and get my hands dirty with the help of my mechanic, but then again, i might as well let him do all the work because i did a good job in obtaining the new carb! I just don't know if I can get a new carb from honda though...
    Sep 2005
    sir, swap engine na pag ganito.
    Feb 2007
    may alam ka bang nag eengine swap puroy? kung meron convoy tayo kaso tatali ko oto ko sa likot ng oto mo! hehehe
    Feb 2007
    seriously kung meron kang alam dude papa engine swap ko na, u are right
Intermittent RPM when idle
