Results 1 to 7 of 7
    Oct 2009
    Sirs ask ko lang ano kayang problem kapag my lumalabas na water sa kinakabitan ng intake manifold at cylinderhead? nahihirapan kasi umistart un sasakyan nauubusan ng fuel sa filter pero ok namam pump. eto ba effect kapag my leak sa intake manifold? Thanks.
    Sent from my SM-J700H using Tsikot Forums mobile app
    May 2011
    What is your make, model year, model, and mileage if your car? Tanong sa hangin suntok sa buwan ang sagot
    Quote Originally Posted by eurostyle View Post
    kung sinusuwerte, "maluwag lang ang turnilyo".
    kung consolation prize suwerte, perished gasket.
    kung mamalasin, engine block/cylinder head crack or warp (previously overheated?).
    Mar 2013
    Quote Originally Posted by mina_nuka View Post
    Natawa ako sir, tama ka nga hehe
    BAKA naman need mo lang palitan fuel hose line mo dahil maycrack na siya better check din sir ng hose clamp. Kung walang crack cut mo ung dulo at ikabit mo uli at reclamp mo na lang, yan ay kung aabot ung hose sir. Konting alam ko lang pagwala sa tamang pressure ang fuel rail dahil mayleak hindi ganun kaganda ang buga ng injectors kaya hirap ka magstart. Tingin ko lang hehe
    Oct 2009
    Carb engine sirs. Its an old 3 cylinder suzuki fronte/alto. Binaklas ko na intake manifold kasi visible un tubig na lumalabas sa pagitan ng intake at head baka gasket kasi. Ano pa kaya dahilan bakit my tubig na lumalabas sa intake?
    is your coolant just water?
    Mar 2013
    Ah ok tubig pla not fuel (bilis ng basa ko hehe), maywater port ang intake manifold at cylinderhhead magkatapat un to bring down temp ng air/fuel mixture para masmaganda ang combustion. Hirap ka nga magstart nyan at medyo rough idle minsan dahil singaw manifold more air than fuel(masama ang timpla hehe). Replace intake manifold gasket (super clean both surface para lapat!) at pantay lang paghigpit ng bolts n nuts ( if you have torque wrench much better).
Intake manifold leak
