Results 11 to 18 of 18
March 6th, 2019 04:06 PM #11
March 6th, 2019 04:19 PM #12
Maybe what ts means by "worth it" is not refering to performance but cost, since changing oem filters at the casa is quite harmful to his wallet? He has a 2016 fortuner so i assume it was casa maintained the past 3 years. A reusable filter, after all, costs less than 2 of the price of the oem. If so, then he needs to balance his savings on replacing oem filters vs the additional wear and tear the ocb filter will result to to his engine. Would ordinary (non-ocb) replacement filters be a better solution to ts' intents? They are priced a third of the cost of oem filters. Do these replacement filters equal the filtratiion efficiency of oem?
- Apr 2010
- 742
March 6th, 2019 04:59 PM #13k&ns for our vehicles cost north of 5000 each. the recharging kit at around 1000 din. some would use 2T or other oils though.
oem filters costs at around 1100-1300. i dust them with an air compressor every 5000KM, and replace every 15000KM
roi is only achieved at the fifth air filter change which is 75000KM
March 6th, 2019 05:36 PM #14
for low mileage use and when periodic maintenance is done once or twice a year, then an oem disposable air filter is just right. in my case, i do PMS minimum 3 times a year so i opted for a washable type air filter. iirc, oem air filter is P1.2k in casa, so thats P3.6k a year budget. my vehicle is more than 6 yrs old/185k+ kms now so i must have spent about P21.6k equiv for air filter alone if i'd stick to oem. the washable air filter was 4.2k back then and still in good shape and do its job until now. sulit na and the savings i had if you convert it to liters of fuel, ilang daang litro din yun. and so far, wala naman isyu sa engine cause by dirt or other particles na nakapasok sa engine internals probably thru air intake.
- Nov 2009
- 3,509
March 6th, 2019 05:44 PM #15If TS is after longevity of engine and saving cost then aftermarket cheap good quality filters are everywhere.
The sakura air filter cost P200 or less, for regular use i'd replace them twice or thrice a year.
Same with oils and other filters, get the cheapest but good quality, even if you frequently replace them(2-3x more) its still cheaper than casa parts. Replace them frequently and your car will last loong.
March 6th, 2019 06:10 PM #16
man that engine will last 300,000- 500,000km
using these highflow airfilters filters will reduce that number to some extent.
how long do you really want to keep that fortuner?
March 18th, 2019 10:52 PM #17
- Dec 2013
- 528
January 10th, 2021 07:35 PM #18I agree with your findings because there are evidences now showing how this so called reusable filters can not filter out as good as those O.E. type filters.
Be careful guys on what you install on your cars especially air filters that claim to be washable performance filters, it will shorten the lifespan of your engine and make it more inefficient faster than normal as time goes by using re-usable "performance" filters.
K&N and BMG filters tested in the United States of America:
1. Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
2. Do performance air filters like BMC, K&N, Sprint let more sand and dust than OEM and is it worth it? - YouTube
K&N filters checked by Master Garage PH, apparently sand and other much smaller particles are going through K&N's air filter even with oil applied from K&N recharger.
Gen 3 Montero Air filter? todas!! - Master Garage - Cavite
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
