Results 1 to 18 of 18
    speedyfix,
    is it really necessary na magpalinis ng gas/fuel tank ang mga newer cars after sometime? may nakapapsabi kasi sa akin na ang mga dapat lang nililinis ay yung mga old diesel cars na metal pa yung tank... yung mga newer cars raw kasi plastic na ang tank...
    if yes, how much po singil niyo sa pag linis ng gas/fuel tank and fuel lines ng 1997 Toyota Corona Exsior?
    gaano po katagal na trabaho ito?
    what's the name, address and contact no. of your shop?
    thanks!
    Feb 2003
    out of the country pa yata si Migs,
    call Felix sa shop nya at
    Speedyfix
    7237625
    Shaw Blvd (beside Toyota Shaw)
    Nov 2003
    thanks wrecker!
    kidd636, may problem ba yung auto mo? if wala kasi then no need to clean the tank. do you replace the fuel filter often? do you fill up in a reliable gas station? if so then no need to clean the tank.
    we only remove the gas if there has been contaminationby having water in the fuel. without removing the tank kasi there is no way to get all of the water out.
    in any case, i'll be back after the elections and you could still contact my mechanics in the shop at 7237625. TY!
    wala naman pong problem sir... i got this car 2nd hand kasi... and i'm reconditioning it right now... so sort of preventive maintenance lang, hindi ko kasi alam totally ang history nung car...
    ...but so far it is running great, very smooth... no signs of fuel startvation or fuel ireggularity problems. i just replaced the fuel filter too, and as much as possible i stick to tried and tested Petron gas stations... XCS gamit ko
    Nov 2003
    in that case no need to remove the tank
    just continue taking care of it and wala ka magiging problema
    why not try draining if yourself muna (may drain hole sa ilalim ng tank). Then check if there are rust or water sa gas na naidrain mo.
    Kung meron, at tsaka mo ipababa, if wala, then just re-fill it up na lang.
    Nov 2003
    pwede rin ito pero normally di mo malalabas lahat ng liquid sa loob kasi there are baffles sa tank. anyway, it's the best 1st step kahit papano
  8. #8
    Speedyfix: Is your shop open on sundays? Do you replace fuel filter? Also do you sell fuel filter for Mitsu Adv? naka 35K Kms na ako when do you suggest replacing a fuel filter? thanks.
    Nov 2003
    sorry, monday to saturday lang kami from 9am-6pm.
    you should probably consider replacing the fuel filter during your next PMS para sabay na sa changeoil and tuneup
  10. #10
    Sir, where is your shop located? Kailangan ba ng appointment para mag pa tune up? I just put Mobil 1 Fully Syn, so my next oil change would probobly be on the 43K Kms range. Ok lang ba yun?
    Aug 2003
    sir speedyfix, do you also check yung sumisingaw or may tagas na gas tank? diba ibinababa yung gas tank pag ganun? gs2 ko din sana for preventive reasons, baka kasi may kalawang na yung gas tank ko. ok ba yun?
    Dec 2003
    iluvdetailing: SPEEDYFIX - located along shaw blvd katabi ng TOYOTA...
    Nov 2003
    ILuvDetailing, nope no need for an appointment for a tuneup. i only recommend this for the larger jobs para we can fix the schedule the day before. yup, mobil 1 full synth will last long naman kaya should be no problem
    jtdc, i doubt may singaw yung tank mo. kalawang... i doubt it. pero we can still check for you if you want
    mugen, thanks for giving the directions!
    Apr 2006
    sir speedy, may question ako if you dont mind.
    un auto ko 1979 lancer, kapamilya ng L-type, di na gumagana un speedometer and kilometer meter (if un nga tawag dun). tuloy di ko alam ilang KM na natatakbo ko. also, di ko namomonitor kung kelan ako dapat magpaservice/maintainance (change oil/ tune up/ etc). diba every KM something dapat ang maintenance.
    with this, how much labor ang pagawa nun?
    just PM me if di mo pwede i-post dito.
    salamat po.
    looking forward na magpagawa sa inyo, kasi dami ako nababasa dito na maganda ang service nyo! congrats!
    Nov 2006
    The best talaga si Sir MIGS and the rest of speedyfix! Hindi pera ang habol sa costumer kundi good service tlga.Kung sa iba iba kayo nagtanong im sure sasabihin pagawa agad yan or palitan ng parts sa kanila kahit di namn sira or whtever.Sana dumami pa ung shop na katulad nyo na di marunong manloko.Long lived speedyfix for tsikoteers!!! Peace!
    Nov 2003
    jundogg, you'll have to pass by the shop so we can check it. the contact info is in my sig...
    three in xe, many many thanks bro!
    May 2005
    okay talaga dyan kay speedyfix. dyan din ako nagpapalit ng timing belt. reasonable price, not cheap but not expensive, a good alternative sa casa.
    balita ko, hindi rin nya pinatatagal ang mga mekaniko nya kung palpak tumarabaho so sigurado kang maayos ang mga gumagawa
    Nov 2003
    hehe! thanks bro! kanino mo nabalitaan yun?
Speedyfix: Gas/fuel tank cleaning inquiry
