Results 11 to 20 of 21
- Jun 2008
- 23
August 13th, 2008 10:00 AM #11tnx! i really like this engine for it's simplicity and raw power (if i can manage to tame it ). your advise is highly appreciated sir, in fact i had it already on my long list of to do's. as of now i'm on top of my checklist and having it DIY. when it comes to your advise it's best i leave it to a professional - though i may still try to do it myself - but will see . Good thing for now is that i'm not experiencing white/black smoke (signs of internal engine problems), pinging, knocking or overheating (signs of wear).
Correct me if i am wrong please:
Idle Mixture screw - regulates the amount of gas flow? air(vacuum) flow? or both instantenously?
Which part of the carb countinously pours gas on idle - main jet or pilot jet?
where is it located in the carb?
TIA
August 13th, 2008 11:21 AM #12
tagat ko na dispatcha corolla liftback ko but i think the lowest screw is for air by pass and above it is Air fuel. You can do a lot of things to that engine pwede mo gawin 1800 by replacing the crankshaft from a 3t. Pwede rin gawin twin cam by replacing the head from a 2tg.
- Jun 2008
- 23
August 13th, 2008 04:09 PM #13later nalang siguro un mods . more on efficiency at FC and objective ko muna . but tnx for the fyi parin.
Note:
i only have 2 adjustable screws in my stock 2bbl aisin carb. one underneath the throttle linkage (idle speed screw) parallel to the screw in the middle of the carb (idle mixture screw). so idle mixture = A/F mixture?
- 72
September 17th, 2008 01:04 PM #14about the a/f screw , yes that is the a/f screw ( pang idle mixture ) may i make a suggestion ? With the engine turn off, remove the screw all the way out of the orifice, then screw it back in slowly, taking note of how many times you turn the screw to fully seat the idle mixture screw.Divide this by 2, this gives you the ( rough ) number estimate of how many back turns of the screw you need to get to the mid way ( half open or close ng idle mixture mo). eto kasi yun theoretical na mixture nung carburator ( based on the screw ), from here you may need a vacuum gauge to fine tune the carburator.HTH ( btw, i got 13T engine, a bigger cousin nung 2T mo,and i do my own carburator overhaul, tuning)
- Jun 2008
- 23
September 17th, 2008 04:40 PM #15it's been a while since i had a reply on this post. was able to learn a bit how carbs work in general within that period. however, though i managed to lower my fc i still have no response from my idle mixture screw. vacuum is good but i may have leaks internally since the engine don't stall when i close the top of the carb. will try to do your suggestion tonight then i'll go ahead with my rebuild on weekend.
- 72
September 18th, 2008 11:39 AM #16another test that u can undertake, is that while the engine is running, remove the idle mixture screw all the way, this should stall the engine. if not ,may problema un carburator.saka do u notice kung magalaw yun needle nung vacuum gauge mo ( normal should be between 15 - 17mm Hg ), this is one sign na may leak ka, pero not always.Kung intake manifold leak, look for signs of gasoline ( sa mga joints ) o un basa sya .
- Jun 2008
- 23
September 22nd, 2008 10:21 AM #17i did the test you mentioned and some other tests too. i had a hunch the idle mixture screw is'nt of the right size along with the jets. which is why i'm having an overly rich mixture and an idle that won't go down. and so as planned i went ahead and rebuilt my carb with a repair kit and carb cleaner. looking at my repair kit and just as i suspected i had the wrong size of mixture screw! alast that explained everything!!!
with high hopes i started to rebuild my carb starting off by thoroughly cleaning it. replaced all gaskets and serviceable parts. could'nt determine the size of the jets coz the marks are unreadable. but based on comparison of the holes i went to the stock jets from the kit for peace of mind
some gaskets aren't provided in the kit so i had to be resourceful and do it pinoy style. like the guy in the auto shop said "eto bossing pedeng pantapal kortehan nyo nalang dun sa base plate. di baleng sumobra ng konte wag lang kulang tapos konting rugby ayos na yan!!".
after putting everything back i did a drip test by filling the gas bowl and moving the carb in slant position to see if it drips. after re-checking for the nth time i finally reseated the carb on the intake manifold and reconnected all lines.
i had few clicks before it cranked, ran then dies. after a couple of attempts it steadied and the first i did was to test the mixture screw and voila! it worked!!! however i was'nt able to properly tune it since it was past midnight when i finished so i had to tune it by giving it a quick turn in till the screw is half way and the engine does'nt stall. happy and contented i went to bed.
afterwork today i'll do the testing and tuning and see if everything worked as expected :D
thanks for all those who posted and thanks tsikot!
- Jan 2008
- 152
September 23rd, 2008 06:24 PM #18cleaning your carb is the best way to start this. it's good that you have.
also have your idling, timing, distributor & high tension wires checked.
you can proceed to more labor intensive (and costly) actions if that doesn't work.
- Jun 2008
- 23
September 24th, 2008 12:35 PM #19finally finished my tuning (i hope). did it twice since the first attempt was under powered (tuning errors due to cold engine). so last night i warmed up the engine first. then with my diy timing light and vacuum gauge i checked the timing. reading from the first timing attempt showed it was over by 10deg (spec is 10' btdc, i had 20'). so i adjusted it to hit 10btdc then checking vacuum gauge to see how accurate my diy timing light is. not dead accurate but so far it was good. after setting the right timing and confirming it with a couple of revs and restarting the engine a few times i moved on to the idle mixture screw.
i started by slowly turning the mixture screw in (clockwise) while closely watching vacuum readings. when the engine started to run sluggish i can see the vacuum reading started to rise and drop. with that i backed 1/4 turn till it started to steady a bit. moving 1/4 turn out till i reached the highest vacuum reading i can get then back 1/8 turn. revved it a couple of times then left it for a while to idle then re-read the vacuum gauge and re-adjust and compensate. when all is good i went for a test drive. with a 500 ml clear bottle with gas i drove the car to a open service road of approximately 1.2 kms from where i am and back. consumption was good it was around 200ml *50-60kph *4th gear (5th gear would open secondaries so i did not engage there to get a reading on city drive). so approximately it was 9-11km/l consumption which is fair considering it's an old engine that used to be 5-6km/l and terrible on idle gas consumption.
my tuning is based on lean best approach (including jetting and secondaries) which keeps the engine a bit under-powered (sakal). my goal right now is to maximimize FC on idle and low end but normal on high end speeds. to do this i still have to understand carbs relationship to engine.
post nalang po dito kung me tips po how to do this. thanks!
- 72
September 27th, 2008 01:28 PM #20btw, san nakakabit yun 2T? saka correct ba ang tire size mo ( baka under size yan ). Pero mukhang o.k naman yun adjustments mo.
3M Crystalline vs 3M Ceramic IR: Which is Best for Your Car? I think Crystalline might be...
